the sucker king Posted January 31, 2004 Share Posted January 31, 2004 as far as at the junkyard, what makes and models (and years) of cars are worth looking under the hoods of for a weber that would work on our cars? Quote Link to comment Share on other sites More sharing options...
mcbrat Posted January 31, 2004 Share Posted January 31, 2004 Opel, BWM 2002, Jeeps, check eBay out for the used webers and see what they came off of .... Quote Link to comment Share on other sites More sharing options...
skeet Posted January 31, 2004 Share Posted January 31, 2004 Some Rangers too right? Quote Link to comment Share on other sites More sharing options...
Qman Posted January 31, 2004 Share Posted January 31, 2004 Nissans/Datsuns, Capri's, Mustangs just about any small engined vehicle will have the chance of someone adding a Weber to it. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted January 31, 2004 Share Posted January 31, 2004 I'll add to this one. Some early Ford's used a VERY similar carb - it's actually a Weber 32/36 DFEV. Uses a different air cleaner (ovalish opening), but uses the same adaptor plate as the DGEV. There are some other slight differences, but the carbs even use the same rebuild kit. It's basically a mirror image of the carb, with a different air cleaner. The air filters (that look just like the ones we use for the DGEV) are availible through EMPI, and everything else should work. The early ford 2.3L engines found in rangers, and I think some pinto's had these stock from the factory. AND best of all, they are jetted correctly for our 1.8's (go figure - very crappy 2.3L I guess...). GD Quote Link to comment Share on other sites More sharing options...
Mike W Posted January 31, 2004 Share Posted January 31, 2004 I'll add Mazda's, Chevy Luv trucks, Toyotas, VWs, etc, etc. In otherwords, just about any import and lots of domestic vehicles too. There's usually tons of them on Ebay. Try searching for just the words "Weber" and "32/36". Happy hunting. Quote Link to comment Share on other sites More sharing options...
Rossta86 Posted January 31, 2004 Share Posted January 31, 2004 GD, on the DFEV is the throttle linkage on the opposite side of the dgev? Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted January 31, 2004 Share Posted January 31, 2004 Yes - the throttle linkage is on the other side on a DFEV. This shouldn't cause any real problem on an EA81 - EA82 I don't know about, but I think it can be made to work at the worst. As I said - the carb is a mirror image - everything is opposite, but the same rebuild kit works for both - they use the same jets - same adaptor plates, and a very similar (but not the same) air filter. The beutiful thing is that these came stock on early ford's, and can be found MUCH easier at JY's. So for the little added issues like the throttle linkage and the air filter, it's worth it to save a couple hundred $$. GD Quote Link to comment Share on other sites More sharing options...
XSNRG Posted February 1, 2004 Share Posted February 1, 2004 Yep, I saw one on a B2600 Mazda truck once. Quote Link to comment Share on other sites More sharing options...
