brat/brumby/284mv - track/drift build
43 replies to this topic
#1 backinbrat
backinbrat
    USMB is life!
  • 195 posts
  • sussex, england
Posted 13 October 2009 - 08:54 AM
well, im bored, so here is a complete spec list and stages of build of my truck
so here it is taking shape now, my truck, finally getting some power!
started off as a standard EA81, single hitachi carb power truck, found on ebay UK in mint condition, which has now changed drastically over the past two years, and yet to change more yet!
here is how its been for the last year odd, with a few small alterations here and there after this piccy was taken
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
the love of old skool rally cars and AE86 and the like drift cars and the like, inspired me to modify the thing that i love, and all i have ever wanted, i love imprezas and all that, but i have fallen big time for the EA's in the last few years! hence the changes!
so after a spec list including:
-subaru 'lowbar' rollbar
-2 maxtel 100W lights
-4 55W fog/driving lights
-Custom made tonnou cover
-Cherry bomb 3" straight through back box
-Facet competition fuel pump
-K&N style breather filters
-high voltage coil
-armtech electronic rev limiter
-52mm tachometer
-52mm oil pressure guage (both in a pillar mount)
-rally flaps
-K&N air filter
-A bar instead of bullbar
-3rd brake light
-weller style, white 8 spoke 16x6 rims, running yoky 205/45/16s
-sparco sprint 5 buckets
-lowered 40mm all round
-sparco rally steering wheel
-bumper bumpettes removed
-tinted rear lights and indicators
-sub woofer and some decent components
its turned out as it is now
after much buggering around with front driveshafts, i gave in, and now run RWD perminently, and this is how its gonna stay! hence the want to make it a more performanced based truck
then came the time for some power
the new long block
Posted Image
the parts altogether, which include SUB 4 dualport heads (ready to go off and be machined) and the matched weber IDF 40's
Posted Image
no more engine! lol
Posted Image
all the parts again
Posted Image
the old engine!
Posted Image
the underneath, with the crossmember alteration to fit the extra exhaust due to the dual ports rear port location (not finished, just a basic shape)
Posted Image
all in all, the engine has
-highlift custom cam from SUB4
-Dual port heads, skimmed for compression uprate
-Twin 40 IDF webers with custom inlet manifolds
-4 branch custom stainless exhuast manifold and alterted crossmember
-high quality bearings, seals, rings all renewed throughout with a brand new old pump
-lightend and rebalanced flywheel
-SUB 4 water circulatory system
more to come so damn soon! including front spillter, adjustable shocks and coilover conversion within the next few weeks!
Edited by backinbrat, 13 October 2009 - 08:57 AM.
#2 GeneralDisorder
GeneralDisorder
    Elite Master of the Subaru
  • 22,054 posts
  • Portland
Posted 13 October 2009 - 09:52 AM
With the added power and the grip you may have issues with eating the rear output transfer gear set. That's a lot of power through a 2.5" gear with small teeth.
Just something to consider. You may eventually have to go with a true RWD transmission.
#3 backinbrat
backinbrat
    USMB is life!
  • 195 posts
  • sussex, england
Posted 13 October 2009 - 09:59 AM
na man, i got ya 100%, it has been a concern of mine, and something i will attend to in the near future, just wanna get it back on the raod, to sort out any teathing problems with the engine, got any intial ideas on a solid RWD conversion? could i do somin with the original trans?
#4 GeneralDisorder
GeneralDisorder
  • 22,054 posts
  • Portland
Posted 13 October 2009 - 10:18 AM
There's nothing that can be done with the original transmission - unfortunately the 4 speed's are complex little items and the output shaft is not inline with the transfer shaft. It would require a lot of machine work and recasting to change it.
I haven't looked into it heavily, but I would start by looking at Nissan truck transmissions. The Nissan stuff from the 80's is about as close as you will find to Subaru's designs. They used a lot of the same parts from the same vendors and there is a surprising amount if interchangability. It will need an adaptor plate for sure, but I think it's worth checking out.
#5 backinbrat
backinbrat
    USMB is life!
  • 195 posts
  • sussex, england
Posted 13 October 2009 - 10:39 AM
ah, i see man, i will have to split another transmission i have, see whats what, and will look into some older nissans, would you specify any particular one? such as shape and model, or is it you just know somin about?
#6 TheSubaruJunkie
TheSubaruJunkie
    I'M BAAAAAACK!
  • 1,938 posts
  • Sacramento
Posted 13 October 2009 - 12:15 PM
Can you go into more detail on how you went about lowering your car? I love the stance!!
#7 backinbrat
backinbrat
    USMB is life!
  • 195 posts
  • sussex, england
Posted 14 October 2009 - 08:46 AM
well, the flywheel came back from the machinists today, looking shweeeet, and 2.5kg lighter :banana:
Posted Image
and in reply to the lowering question, simply cut the springs by one coil on the front, and clocked the torsion bar a notch on the rear, then the 16" wellers, i cant tell you the offset, cause i dont know! i can check next time im up the garage
now im just waiting for the restof the machine work to be done:rolleyes:
#8 TheSubaruJunkie
TheSubaruJunkie
    I'M BAAAAAACK!
  • 1,938 posts
  • Sacramento
Posted 14 October 2009 - 08:45 PM
awesome, I am going to be getting new struts and then worrying about springs after that. Great build, keep this thread updated!
#9 Ricearu
Ricearu
    Official De-Ricer!
  • 1,214 posts
  • DFW, TX
Posted 15 October 2009 - 12:32 AM
Dude that is a freakin sweet brat, I would look into a S13 chassis Nissan 240sx transmission. They are a DIME per dozen at the local wrecking yards and pretty tough. A friend of mine has a 240 and has the SR20DET Blacktop (240HP) through the stock (non-turbo) transmission and it holds up well. I think they might break if you exceed 300HP, but without a STI engine, you don't have to worry too much about that!:lol:
Also, look into doing the Impreza GC8 Hub/spindle conversion while you are at it, because the brakes are better (expecially for competition) and you can get name brand performance suspension components for it. Suberdave runs TIEN's for an 05+ legacy with EDFC's. Check out his site!
http://www.suberdave.../flex/index.htm
I would like to someday build a drift wagon to compete in some drift events for fun.:grin:
#10 someguy
someguy
    New User
  • PipPip
  • 25 posts
  • Adelaide, South Australia
Posted 15 October 2009 - 12:34 AM
Did you have to do much alterations to the seat rails to fit the sparco seats?
I am looking to something similar with my wagon.
#11 backinbrat
backinbrat
    USMB is life!
  • 195 posts
  • sussex, england
Posted 15 October 2009 - 03:37 AM
ah, i shall look into a s13 transmission, that might be worth pursuing, as well as a rear LSD, which im also on the look out for, if anyones got one? and also a big pleasy is rear discs, both these items are obsolete over here!
i'll check out that link when i can, but techno toy tuning can provide adjustable weld on spring seats and camber/caster plates for this with only a little redrilling required, and then putting just the shocks or some soft sprung adjustable coilovers on the rear with the torsion bar, ideally im after the least hasstle route, it may be worth considering
and i highly doubt this will be used in competition, its just my love child really, and i wanna do a few drift what ya brung days, and generally have a giggle, be pretty sick if you saw it on tv for the european drift championship though :P
the sparcos mount quite simply really, i got the idea off subarubrat.com, cut 2 pieces of box section to the same length as the original seat runners, then weld on 2 pieces in the right place at each end, drill some holes in it, wah lah, you have custom seat runners that will take pretty much any bucket seat!
Edited by backinbrat, 15 October 2009 - 03:39 AM.
#12 Ricearu
Ricearu
    Official De-Ricer!
  • 1,214 posts
  • DFW, TX
Posted 15 October 2009 - 03:25 PM
while you are in custom fab/trans town, look into an Infinity J30 rear end. They are all LSD factory. Just have to find axles and build a mount point.
#13 Subarutex
Subarutex
    Oldschool Show Queen
  • Moderator
  • 2,551 posts
  • Mountlake Terrace
Posted 15 October 2009 - 03:42 PM
Why stop at just the rear end?
Lets me honest, torsion rear suspensions are ancient.
Just as easy you could fab up a 4 link to a solid axle, or even do a subframe swap out of a s13/14/r32.
#14 Ricearu
Ricearu
    Official De-Ricer!
  • 1,214 posts
  • DFW, TX
Posted 15 October 2009 - 04:54 PM
yeah i would subframe it, and use the J30 diff. The last one I bought cost me $45 at Pick-n-Pull! They had like 6 j's out there and 4 had diffs, I got mine from a 95k mi wrecked up front J30.
DRIFT TRUCK FTMFW! Its unibody so it counts!!!!
#15 backinbrat
backinbrat
    USMB is life!
  • 195 posts
  • sussex, england
Posted 16 October 2009 - 05:22 AM
hmmm, this infinity J30, i have never seen one, and not seen one in the UK! they dont even import infinitys offically here! lol
the S13 route is one i might well look into, theres shed loads of them over here, and they all just blow up haha! so planty of LSD's im sure there are kicking about!
would rather keep it all subaru really, full coilovers would be nice, would i right in saying they were on the RX's and similar? but i will look out for alternatives!
#16 Phizinza
Phizinza
    Yip yip
  • 3,939 posts
  • South Australia
Posted 16 October 2009 - 05:42 AM
I do like those wheels... I'm so tempted to do a road going awd leone but ....:-\
#17 backinbrat
backinbrat
    USMB is life!
  • 195 posts
  • sussex, england
Posted 16 October 2009 - 12:31 PM
i really want a leone, do a drift build on that, that would be sick! lol
i need a 4 seater ideally! its only me and one other that i can transport around!
anyone know where i could get one, a EA81 shape one, sedan, if theres one avalible, let me know, and it cant be 2wd or auto! lol!
#18 Phizinza
Phizinza
    Yip yip
  • 3,939 posts
  • South Australia
Posted 16 October 2009 - 10:04 PM
In Aus they only came 2wd. And if you want to put 4wd in without a lift I would highly recommend getting an auto (more trans tunnel room, less cutting)
#19 backinbrat
backinbrat
    USMB is life!
  • 195 posts
  • sussex, england
Posted 17 October 2009 - 06:55 AM
oh, lol, just so happans theres a 2wd auto one on ebay AU lmao! well tempted but ive got enough projects! would just like a 4WD one, then pop the front shafts, that would be so rood! lol put the rims i got on my truck now on it, then drop it a bit, so did they come in 4WD format? and i have seen yours on youtube, think you sent it to me, with the new at the time exhuast system
#20 nolicense
nolicense
    USMB Regular
  • PipPipPip
  • 55 posts
  • Everett
Posted 19 October 2009 - 06:52 PM
the infinit j30 is also known as the nissan Leopard J Ferie. if you have those over there..
#21 backinbrat
backinbrat
    USMB is life!
  • 195 posts
  • sussex, england
Posted 20 October 2009 - 04:11 AM
lol, nope, never seen one before in my life! haha!
#22 XTREME RACING
XTREME RACING
    USMB Regular
  • PipPipPip
  • 41 posts
  • YORK, SC
Posted 06 November 2009 - 08:57 AM
just checking to see if you have got the backspace on your wheels.
BTW, it looks great!!!!
#23 backinbrat
backinbrat
    USMB is life!
  • 195 posts
  • sussex, england
Posted 07 November 2009 - 11:24 AM
yeah, soz, i have only just got internet rigged up, have moved house, so been trying to sort stuff, will check the offset on monday when the garage is open
#24 Uberoo
Uberoo
    Subaru Wheeler
  • 3,863 posts
  • lewiston,ID
Posted 07 November 2009 - 11:43 AM
when do we see some pics/video of it drifting? It can be done on asphalt, wet pavement, or gravel.
#25 XTREME RACING
XTREME RACING
    USMB Regular
  • PipPipPip
  • 41 posts
  • YORK, SC
Posted 07 November 2009 - 03:51 PM
cool, thanks so much.
