raising an outback wagon
2 replies to this topic
#1 Guest_Bob Alexander_*
  • Guests
Posted 17 June 2003 - 12:40 PM
I just bought a 2003 outback wagon. I'm looking for a way to improve ground clearance when off-roading. An adjustable system that can be controlled from inside the vehicle (like an Audi allroad) would be perfect. If not available, I'm looking for a source for a lift kit. Thanks.
#2 Guest_Legacy777_*
  • Guests
Posted 17 June 2003 - 03:53 PM
You're probably asking for a little much with the in car height adjustment.
Check out www.isrperformance.com they have scorpion lift kits.
#3 Guest_soilmapper_*
  • Guests
Posted 18 June 2003 - 07:49 AM
I don't think you will find any air-based suspension systems, but something might be out there.
A much cheaper alternative would be the springs and lift kit from ISR. I just put the springs on my 97 OB wagon (64 k). I would definitely recommend them for this car. I think the car should have come with them from the factory.
They have not only improved ground clearence, but also (along with new struts) tightened up the handling. Much less body roll with bikes and gear on the roof.
Hope this helps.
