Code P1507
1 reply to this topic
#1 BushmasterSI
BushmasterSI
    USMB Regular
  • PipPipPip
  • 61 posts
  • Atlanta
Posted 09 November 2009 - 08:48 PM
After my head gasket job, I had a DTC of P1507 which the FSM said was the Idle Air Control Solenoid valve. I removed it and cleaned it thoroughly with electrical contact cleaner and I think I've solved the problem. The valve was gummed up with grease/crud from the crankcase gasses. Before I cleaned it it had a slight resistance when turning it manually and aftwerwards there was no resistance at all.
It's been a day since I cleaned it. Hopefully the CEL won't come on anymore.
Here are some pics:
Posted Image
The IAC valve is in the center under the big black PCV hose. It's got the grey three pin connecter connected to it.
Posted Image
Posted Image
I broke the PCV tee by pulling too hard on the line. It came loose and I broke it. I should have used pliars or a screwdriver to pry it off instead of pulling :)
Posted Image
Posted Image
Posted Image
#2 Legacy777
Legacy777
    Moderator
  • Moderator
  • 12,809 posts
  • Houston, Tx
Posted 10 November 2009 - 11:23 AM
Thanks for the pictures. Those old plastic PCV pieces tend to get brittle and crack....no fun.
