AC Belt tensioner
8 replies to this topic
#1 Guest_97SubaruGT_*
  • Guests
Posted 15 June 2003 - 09:17 AM
Hi everyone.
The tensioner for the AC drive belt cracked.
My belts started squealing and I decided to check, good thing i did.
The tensioner is tightened for the near future it should be ok to drive but eventually I want to replace the darn thing.
Does anyone know the part number for this thing? I seem to be two parts, one is the wheel and the other is the rail mount. I attempted to paste a link to the pic, hope it works. Anyone know the price range for this thing?
<img src="http://img.villagephotos.com/p/2003-6/233953/tensioner.jpg" style="border:0;"/>
#2 Guest_scoobtech_*
  • Guests
Posted 15 June 2003 - 10:15 PM
These should come as a complete assy.0]
#3 Guest_TinyClark_*
  • Guests
Posted 15 June 2003 - 11:50 PM
If it's too pricey, maybe it can be welded.
#4 Guest_Legacy777_*
  • Guests
Posted 16 June 2003 - 06:10 AM
I wouldn't try to weld it. Just get a new one. If price is an issue, get one from a junkyard.
#5 Guest_scoobtech_*
  • Guests
Posted 16 June 2003 - 04:58 PM
You can' t weld because that is how you adjust the belt . :cool:
#6 Guest_canajun2eh_*
  • Guests
Posted 16 June 2003 - 07:34 PM
Wow! That shouldn't happen.
Did you forget to loosen the pulley nut before trying to tighten the belt?
Just get a used one from a junkyard. $5 ought to do it.
#7 Guest_TinyClark_*
  • Guests
Posted 17 June 2003 - 12:16 AM
You can weld it to work the same as new, but if you can get one at a junk yard, that's the best bet.
#8 Guest_97SubaruGT_*
  • Guests
Posted 17 June 2003 - 06:47 AM
Yup, i didn't loosen the nut before trying to adjust the pulley and the thing cracked.
I went to the dealer and got that guide piece for ~$7. No wonder it cracked, it's plastic.
I'll have fun trying to loosen the nut, there's only around 2" of clearance between the pulley and the fan.
Thanks for the help everyone.
#9 Guest_Legacy777_*
  • Guests
Posted 17 June 2003 - 03:51 PM
The old ones are metal, and what usually happens when someone does exactly what you did is the long bolt bends.
I would say not loosening the idler pulley is probably a very common uh-oh.
