Markus56 Posted November 12, 2009 Share Posted November 12, 2009 I want to put a 6" lift on my car to upgrade it from the 2 inch that is on it now. i am thinking have a 4 inch drop in the rear with 6 inches on the rear struts and 6" all the way across in the front. What metal do i need, how many pieces, what size holes to drill, and how long should the flat bar in the rear be before i bend it? and any other stuff i am missing Thanks! Quote Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted November 12, 2009 Share Posted November 12, 2009 I want to put a 6" lift on my car to upgrade it from the 2 inch that is on it now. i am thinking have a 4 inch drop in the rear with 6 inches on the rear struts and 6" all the way across in the front. What metal do i need, how many pieces, what size holes to drill, and how long should the flat bar in the rear be before i bend it? and any other stuff i am missing Thanks! use 2 x 4 rectagular steel for the drop blocks, check out this thread http://www.ultimatesubaru.org/forum/showthread.php?t=97445 6" at the struts, 5" at the diff and engine crossmember Quote Link to comment Share on other sites More sharing options...
3eyedwagon Posted November 12, 2009 Share Posted November 12, 2009 John, Have Jeff get ahold of Woody, and ask if you can crawl under his car with a tape measure. There should be plenty of room to crawl around under there. It usually only sits one of two places when not in use. Woody will tell you where it is if he's cool with it. Take a tape measure with you, and a notepad. Measure all of his blocks. He did some pretty intelligent stuff, so I would take the opportunity to copy a bit from a very tried, and true car built by a very smart dude. I've said this before, and I'll say it again. Nobody will be able to tell you EXACTLY what your car will need. Things like strut extensions, and steering shaft extensions seem to all be a hair different on everybodys cars. But, Woodys car is a perfect example for you to take the important measurements from. Quote Link to comment Share on other sites More sharing options...
Osubaruwagon Posted June 4, 2012 Share Posted June 4, 2012 i have a 89 gl wagon raised roof i want a 6 inch lift.....it says i need to lengthen steering shaft.....how do i go about doing this? Quote Link to comment Share on other sites More sharing options...
Prwa101 Posted June 5, 2012 Share Posted June 5, 2012 i have a 89 gl wagon raised roof i want a 6 inch lift.....it says i need to lengthen steering shaft.....how do i go about doing this? Hey dude, it's pretty easy I did mine I have a 4" lift on my gl. Pretty much you just cut your stearing knuckle in half and weld a longer tube in between the cut for the exstention. Could Make on for you if you can't? -Prwa101 Get me at godslambs@aol.com Sence you cant pm. Quote Link to comment Share on other sites More sharing options...
