how do i check to see if a coil pack is working properly?
Well, I sprinkled water on mine and it replicated the problem. So you can try that if the coil is the problem
Otherwise, I assume you have a 2.5 engine. If so, the spark plug tube gaskets are common leakers. The oil drips from the tube gaskets saturate the wires which causes misfires.
