On the bottom of yhe tranny you will see three bolts in a row, I think they are a 10mm head. Take each one out one by one and check the condition of the ball and spring. Might need to stretch and/or replace the spring, or replace theball if it is worn. The balls ride in grooves in teh shift rails and are what holds it in gear, when they wear out or get loose, then it wont' stay in gear. Usually the balls wear, and replacement will fix it, btu sometimes the detent in the shift rail gets worn and in that case, you have to replace the shift rail. Yous hould be able to get teh balls and springs from the dealer for relatively cheap.
