Busted hood release-How to break into hood?
6 replies to this topic
#1 moosens
    Vintage Subathusiast
  • 1,945 posts
  • Bridgeport CT
Posted 04 February 2004 - 01:04 AM
Haven't started looking for a way yet.Thought I'd look to experience first.
1987 Turbo wagon EA82T
#2 Caboobaroo
    USMB Drunk
  • 7,157 posts
  • Oregon City
Posted 04 February 2004 - 01:24 AM
aww come on Paul, you should be able to do this:D I'm not quite sure on that style of wagon but I know on my 79, I had to wiggle a screw driver through the grille and press on the little lever that is pulled by the cable. It took me about 30 minutes to do it but I finally got it open and pulled out the hood release mechanism. I hope you can figure this out;)
#3 GLCraig
  • 2,706 posts
  • Canby @#$% Oregon
Posted 04 February 2004 - 01:25 AM
If you reach up between the grill and radiator there is a short arm that sticks out of the release mechanism that you can pull to release the hood. It's a really tight squeese to get your hand in there if it has A/C.
#4 torxxx
    I void warranties
  • 2,918 posts
  • Fairbanks
Posted 04 February 2004 - 01:46 AM
I dont have AC and I can get my hand in between the rad and the grill..
hook a few zip ties to it and have them come out of the grill.
#5 Turbone
    The Original Rob
  • Moderator
  • 12,203 posts
  • WA
Posted 04 February 2004 - 01:53 AM
If you dont want to mess up the finish on the hood, use a flat piece of metal stock about 1/8th thick. The latch is on the right side (you prob knew that) and push towards the right (you prob knew that too).
#6 moosens
  • 1,945 posts
  • Bridgeport CT
Posted 04 February 2004 - 06:42 PM
I'll give it a shot later....in the dark....shot in the dark haw haw haw yuk yuk....I have a Jimmy-bar that should work.Or something.
#7 88xt6joe
  • 358 posts
  • Boise
Posted 04 February 2004 - 08:54 PM
I just got up there with a coat hanger and put it through the hole for the hood latch and pulled towards the drivers side. Pretty easy.
