mitch184 Posted February 4, 2004 Share Posted February 4, 2004 Yeah, i finally got my lsd in. Now whenever i shift into 4wd while i'm moving and i'm in gear with the clutch depressed, it takes about 4-5 seconds before it shifts and then i get a huge clunk. If i do the same thing with the clutch depressed but in nuetral, it only takes about 1-2 seconds then shifts smoothly. Moral is, when i'm in gear it shifts like crap, when in nuetral it is smooth. I don't know if this is related to the new lsd, but it sounds like something is going to break if i keep doing it. Any ideas? Quote Link to comment Share on other sites More sharing options...
NoahDL88 Posted February 4, 2004 Share Posted February 4, 2004 First off make sure your not shifting into 4wd on asphalt, second check to make sure your tires are all the same size, i had that problem with mine when i was running 175's and 185's, not my fault, they were like that when bought the car Quote Link to comment Share on other sites More sharing options...
mitch184 Posted February 4, 2004 Author Share Posted February 4, 2004 it was on asphault, but i was going in a straight line so i thought that it wouldn't make a difference as i had done this in the past without such a major clunking. Quote Link to comment Share on other sites More sharing options...
Qman Posted February 4, 2004 Share Posted February 4, 2004 What car are we dealing with here? Quote Link to comment Share on other sites More sharing options...
Skip Posted February 4, 2004 Share Posted February 4, 2004 Q, are you thinking he may have a 3.7 LSD rear with a 3.9 front? If this is the case would the clutches in the LSD slip enough to allow the vehicle to roll?? Little off topic but until Mitch tells us this is not his 92 Silverado I would just like your thoughts. Quote Link to comment Share on other sites More sharing options...
Qman Posted February 4, 2004 Share Posted February 4, 2004 That's what I'm thinking. And it could be the clutches binding and popping that he's hearing. I don't think it would slip enough to not bind the drivetrain. Quote Link to comment Share on other sites More sharing options...
mitch184 Posted February 4, 2004 Author Share Posted February 4, 2004 It's 3.7 all the way around. Its an 87 turbowagon 5 spd. The noise is getting better somehow. i jacked the rear tires off the ground and spun them. I can grab one wheel and rotate it about 10-15 degrees before the other tire and the pinion starts to rotate. I had a jeep with a locker that did the same thing and i was wondering if this is normal on lsd's too. Quote Link to comment Share on other sites More sharing options...
