Need help with tranny/engine swap
7 replies to this topic
#1 RAugur33
RAugur33
    Eat, Live, Breath Subaru
  • 282 posts
  • Portland
Posted 30 November 2009 - 04:57 PM
How are you connecting the tachometer in the EA81 to EJ22 swap?
Do I need an aftermarket tach?
Thanks.
BTW: swap passed emissions today!
Edited by RAugur33, 08 December 2009 - 05:47 PM.
#2 RAugur33
RAugur33
  • 282 posts
  • Portland
Posted 08 December 2009 - 06:05 PM
old title; new question.
#3 jrettenmayer
jrettenmayer
    USMB Regular
  • PipPipPip
  • 107 posts
  • Bozeman
Posted 08 December 2009 - 07:43 PM
Pin c10 or c16 or something like that (the wire is black with a blue stripe) comes off the ECU and splices into the tach signal wire that should be coming from your coil. On my EA82, it was yellow.
#4 gwilson87
gwilson87
  • 278 posts
  • Orem, UT
Posted 08 December 2009 - 08:19 PM
If you have/had a donor car I found it helpful to keep the old gauge cluster because then I can trace wires when my tape that was labeling them fell off. Use the pinout that numbchux has on his website and that will tell you what wire is supposed to be the tach wire, and then find the one that comes off your gauge. It is kind of confusing but at the same time not. I spent a few days just following wires around because I kept second guessing myself, but it ended up working. I recommend reading the conversion manual in the sticky of this section, at least 3,4 or 6 times :)
#5 s'ko
s'ko
    RIP
  • 1,722 posts
  • Los Angeles
Posted 11 December 2009 - 10:58 AM
if you need more specifics, list year of both cars and I can help with what wires to connect.
BTW CONGRATS ON PASSING SMOG
:banana:
#6 Gloyale
Gloyale
    It's a sickness
  • 10,834 posts
  • Corvallis, OR PNW
Posted 11 December 2009 - 01:22 PM
Run the tach wire from the EJ harness to the yellow wire in the FPCU (fuel pump control unit)
It is mounted on teh driver side kickpanel, above the hood release. You don't need it anymore with the EJ harness controlling the pump. So you can just unplug the connetor, put a male spade on your EJ tach wire, and plug it into the yellow wires slot.
#7 RAugur33
RAugur33
  • 282 posts
  • Portland
Posted 25 December 2009 - 05:27 PM
Ho Ho Ho; hooked up the tach today. Thanks to Gloyale and all of you for helping me out.
#8 briansr1
briansr1
    Newbie
  • Pip
  • 2 posts
  • New Jersey
Posted 11 December 2013 - 02:27 PM
I am swapping an 09 legacy 2.5 into an 85 vanagon.
I need some wiring help. Any where to get diagrams?
