How to put timing belt back on after you just replaced both heads
4 replies to this topic
#1 chuck37
chuck37
    New User
  • Pip
  • 2 posts
  • Wantage New Jersey
Posted 02 December 2009 - 09:31 AM
Ha I have a 2001 Legecy and I am going to replace the heads are there any tips on getting all the timming marks line up after you just put new heads on:)http://www.ultimates...ilies/smile.gif
Thanks Chuck
#2 idosubaru
idosubaru
    Elite Master of the Subaru
  • 24,014 posts
  • East Coast
Posted 02 December 2009 - 09:49 AM
it's no different than installing a timing belt any other time. is there something confusing you or different about it than normal? what exactly are you wondering?
i would search here or look for johncegglestons(?spelling) user name, he has the endwrench articles posted in his signature.
endwrench is Subaru's internet supplied direction, it's all you need.
#3 chuck37
chuck37
    New User
  • Pip
  • 2 posts
Posted 02 December 2009 - 10:20 AM
I have never put a timing belt on before I have work on cars with timing chains back in the day but not a car with timing belts.
#4 idosubaru
idosubaru
  • 24,014 posts
  • East Coast
Posted 02 December 2009 - 10:29 AM
Yeah just search for links to those endwrench articles, they're fantastic. Straight from Subaru with pictures and all. Search button is up a bit in that line of header options. Click on advanced search - select the new gen forum and search for timing belt.
Good luck, they're straight forward and fairly simple, but they are an interference engine so want to get them right!
#5 johnceggleston
johnceggleston
    Lite Master of the Subaru
  • 6,712 posts
  • Virginia
Posted 02 December 2009 - 02:09 PM
if i can do it....
it not that hard, make sure to use the correct crank sprocket timing mark. when you are using the correct one, the crank sprocket keyway will be down in the 6 o'clock position.
dual cams are a little trickier, but i don't think the '01 legacy has dual cams.
see link below.
