hill holder
10 replies to this topic
#1 akc
akc
    USMB is life!
  • 173 posts
  • gig harbor
Posted 06 December 2009 - 11:56 AM
I noticed the other day that my hill holder is disconnected on my subie. I was wondering if it is worth fixing as I do not think any of the subies I have owned have had a working one (all 2 of them). Or is it more of a bother and no one uses them anyway.
#2 hardtail_pride
hardtail_pride
    Eat, Live, Breath Subaru
  • 280 posts
  • Orem
Posted 06 December 2009 - 12:36 PM
Mine works and is kinda nice to have. Its not a necessity, but more like a luxury accessory.
#3 Speedwagon
Speedwagon
  • 446 posts
  • Denver, CO
Posted 06 December 2009 - 06:47 PM
I guess it really depends on if you have any hills in your area, and if you feel like being lazy on the clutch/gas when starting.
#4 akc
akc
    USMB is life!
  • 173 posts
  • gig harbor
Posted 06 December 2009 - 06:50 PM
I have tons of hills and teenage drivers. I do not mind the hills but sometimes the teen drivers do. What tends to go wrong with the hill holder I am sure it must have been disconected for some reason??
#5 GeneralDisorder
GeneralDisorder
    Elite Master of the Subaru
  • 21,916 posts
  • Portland
Posted 06 December 2009 - 06:54 PM
Typically the cable breaks or it's not adjusted right so the cable get's removed. They don't really fail - they can leak but it's not common.
#6 akc
akc
    USMB is life!
  • 173 posts
  • gig harbor
Posted 06 December 2009 - 07:14 PM
Thanks GD I might try hooking it up to see if it works then. The cable appears ok. Who knows I might like it. I have a friend that loves theirs.
#7 GeneralDisorder
GeneralDisorder
  • 21,916 posts
  • Portland
Posted 06 December 2009 - 07:49 PM
They are dangerous off-road and so I rarely use them. If you *need* to roll backward because of a tipsy situation they can get in the way.
#8 edrach
edrach
    RIP 6/28/14
  • 12,326 posts
  • Bothell, WA
Most often, as GD says, they don't fail but are mis-adjusted so they appear not to work. Too loose and they don't hold; too tight and you don't disengage the brake as you let out the clutch.
Here's a tip on adjusting it: Tighten the cable until you can just squeeze a dime between two turns of the coil spring. Use the dime like you would a feeler guage. You might have to tweak it just a hair from that, but generally that works just perfectly for me.
2nd tip: Make sure your clutch cable is properly adjusted FIRST. Also make sure you test it on a hill not on a level street.
#9 akc
akc
    USMB is life!
  • 173 posts
  • gig harbor
Posted 06 December 2009 - 08:21 PM
Thanks Edrach that was my next question you answered before I thought to format it.
#10 zoobaru_91
zoobaru_91
    New User
  • Pip
  • 9 posts
  • Clatskanie
Posted 06 December 2009 - 09:23 PM
I've had mine some-what freeze up on me in the cold on flat ground. forcing me to rev the engine up nice and high while slipping the clutch to break it loose....not my favorite thing to do.
#11 edrach
edrach
    RIP 6/28/14
  • 12,326 posts
  • Bothell, WA
Posted 07 December 2009 - 09:29 AM
If that's the case, adjustment is too tight. Loosen it up a tad.
