oil pump removal 86 gl hatch
4 replies to this topic
#1 rayban1
    USMB Regular
  • PipPipPip
  • 54 posts
  • Seattle
Posted 06 December 2009 - 03:54 PM
I have a 86 gl hatch 1.8L, trying to remove the oil pump. Have removed the 4 10mm bolts, pump rotates slightly but won't give. Am i missing something. Thanks Ray.......
#2 GeneralDisorder
    Elite Master of the Subaru
  • 21,798 posts
  • Portland
Posted 06 December 2009 - 05:37 PM
Nope - 4 bolts, rotate and pull. DO NOT pry hard on it. You will break the housing.
Some people have found it neccesary to loosen the block half bolts in the vicinity of the oil pump. I've never had to do this - just rotate back and forth as you pull - sometimes I will pry VERY GENTLY as I rotate. It helps to have the oil filter still attached as a lever for rotating it.
It's just bound up with oil varnish.
#3 torxxx
    I void warranties
  • 2,918 posts
  • Fairbanks
Posted 06 December 2009 - 07:59 PM
give it a lil tappy poo with a dead blow hammer. what ever you do, do NOT stick a screw driver in there and try to pry it out that way. you take a major chance on ************ing up the mating surface and then the pump will never seal up
#4 rayban1
    USMB Regular
  • PipPipPip
  • 54 posts
  • Seattle
Posted 06 December 2009 - 09:38 PM
Thanks got it , just needed that gentle tap.......
#5 rayban1
    USMB Regular
  • PipPipPip
  • 54 posts
  • Seattle
Posted 06 December 2009 - 09:41 PM
Also leaving the oil filter on to help rotate was helpful , thanks again....Rayban1
