Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
88 Justy Carb replace
#1
Posted 07 December 2009 - 09:00 PM
#2
Posted 07 December 2009 - 10:21 PM
You didn't say one barrel or two.
Doug
#3
Posted 07 December 2009 - 10:22 PM
#4
Posted 07 December 2009 - 11:07 PM
#5
Posted 07 December 2009 - 11:11 PM
I don't know where "Humboldt, Eureka area" is. I've seen reference to 1L, 1 barrel Justys.
This could be a feed back carb?
Doug
#6
Posted 07 December 2009 - 11:16 PM
#7
Posted 08 December 2009 - 02:14 AM
Northern CaliforniaI don't know where "Humboldt, Eureka area" is. I've seen reference to 1L, 1 barrel Justys.
It is my understanding that only the 1.2L was sold in the U.S.
So chefgeoff, are you planning on swapping out an '88 carb? Depending on what your answer is, there may be more advice to follow.
#8
Posted 08 December 2009 - 02:48 AM
Take a look at this thread, and there's another there as well. http://subarujusty.p...lay&thread=2257
A carb kit and a gallon of carb chem dip will cost you about $50.00. A chem dip of your carb is probably required to insure it works right when back together.
Last Justy feedback carb I had, I replaced it with an ebay remanufactured for, I think it was $110.00. That was on an '89.
Doug
#9
Posted 08 December 2009 - 03:10 AM
#10
Posted 08 December 2009 - 10:02 PM
Check carefully, the '89 looks very similar, but has some differences. I can't elaborate since I have neither an '89 carb at the moment nor an '89 FSMI just bought a new carb, so that is what I will be putting in, should be the same as the old one (I hope)
It's not, and BTW your carb is obviously not "new". Where did you buy it? You should check to make sure it is not in worse shape than the one on the car. It is easy to make a carb look new. Do you have a multimeter? I recommend checking the duty solenoid (DS) of the "old" carb while it is still on the car. The diagnostic in the FSM is almost entirely for a DS that is installed. I can post a photo of the diagnostic flow chart if you are able to use it. I also recommend using Gasgacinch on the base gaskets to seal it really good, especially since the carb is such a PITA to remove and install. Check to see if the factory installed aluminum plug was drilled out to allow access to the idle mixture screw.Ive never replaced a carb, but it doesn't sound too intimidating.... I hope its not too hard.
Hell yeah, I was a wildlife treeclimber for many years in college and spent many a glorious afternoon in the canopies of California Redwoods. I have been around the world, and NorCal and Southern Oregon are easily one of the most amazing regions in the world.Cheers to ferox for knowing where humboldt county is.
Y'know, whenever I went to Northern Cali I saw these little stickers on cars. They were of a golden five or seven -lobed serrate leaf inside a gold circle on a black background. What was that all about?
#11
Posted 06 April 2010 - 03:25 PM
Its an 89 2dr 2wd.
