Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
Getting those transmission blues...
#1
Posted 11 December 2009 - 08:09 AM
Last winter, the cold did not affect the way the car shifted.
Last night and this morning, on down- and up-shifts the engine raced up a bit between shifts, sometimes engaging with a bang on a downshift (similar to my ever-present high-speed 4-3 downshift bang, but that is only at high-speeds, high-throttle).
No delayed forward movement, just during shifts.
I presume some of the internal seals are either more 'swelled' than they used to be, and dragging (resisting movement) when it's cold, or the exact opposite, the seals are that much more 'dried out' (harder) than last year, and the cold is bringing out the worst of it.
I bought the with 55kmiles 2 years ago, got a full trans flush then, 117k now, still safe to do a full flush or should I do it bit by bit, is what I have to figure out.
Also, should I switch to synthetic?
After a flush or series of changes, I can worry about what magic pixie-dust additive may or may not work.
Dave
#2
Posted 11 December 2009 - 08:21 AM
#3
Posted 11 December 2009 - 08:50 AM
my H6 OBW doesn't shift great, has some harshness to it, but i've never worried about it. it's most noticeable when passing up a mountain grade at interstate speeds, dont' really notice it for around town and normal driving.
I avoid all additives for transmissions, drain and refill for now sounds good to me over the quick fix route.
The LSD additive for the torque bind is one exception.
good luck dave and report back.
#4
Posted 11 December 2009 - 02:38 PM
does it do it all the time or only certain times? same cold/warm?
Since I got the car the only harsh shift was a 4-3 downshift above 65 or so, and that has not gotten worse.
Gary and Rooster,
I shy away from additives as well, but a number of folks here use the trans-x trick for delayed forward engagement with good results, so I know it can help a seal seal.
I'm also wondering if the harsh shift is a TPS issue, since it seems only the H6 has the harsh 4-3 shift, and the H6 TPS goes bad a lot more often than the H4 TPS (they are different).
Dave
#5
Posted 11 December 2009 - 04:37 PM
Ah ha, I think that describes mine as well - the 4-3 downshift at highway speeds. If you ever hear anything about that, post it! I don't really mind it, I've always disconnected the "shift resistor" on older 4EAT's to firm up the shifting, but this is particularly hard and the wife drives it a lot!
Good luck.
#6
Posted 13 December 2009 - 04:30 PM
Dave,
Good luck.
I accidently drained down my battery (I had turned on the parking lights on purpose, but forgot) and resetting all the codes/learned behavior seemed to ease the 4-3 shift for awhile.
Try that and let me know- I just haven't had a chance to repeat the experiment.
Dave
#7
Posted 13 December 2009 - 05:12 PM
#8
Posted 13 December 2009 - 11:19 PM
#9
Posted 13 December 2009 - 11:28 PM
You may want to find a (God help me for saying this) a good tranny shop or better yet a dealer. Dealers dont like selling transmissions. Leave the car overnight and have them throw a set of pressure gauges on the car. They should be able to see this happenening on the gauges.
nipper
