wipres quit
2 replies to this topic
    USMB is life!
  • 205 posts
  • vancouver
Posted 22 December 2009 - 06:19 AM
need help the Winchell wipers stoped working
looked at the fuse box no bad fusees
washer stop working at the same time
this would be on a 8 gl10 turbo
wiper moter?
hmm going to look in to it in the morning any help in the mean time would be grate
#2 eulogious
    Inspiring Subaneer
  • 1,090 posts
  • Olympia, WA
Posted 22 December 2009 - 07:07 AM
You say the washer stopped working at the same time as well? Does the washer motor sound at all? If you run power directly to the washer pump, does it pump anything? How about running power directly to the wiper motor, does it do anything? I ask all this because if the washer pump works with direct power, and the wiper motor works with direct power, then it's the switch. Otherwise it's probably the motor. Since the washer quit working at the same time, I would lean toward the switch failing, or a wire getting grounded somewhere along the way. That would be where I would put my money given the info so far...
    USMB is life!
  • 205 posts
  • vancouver
Posted 22 December 2009 - 01:59 PM
was in the mud trying to wash the the mud off
going to run power to th moter & see if it works...
I'm thinking its the switch we will find out
