wowzers Posted January 7, 2010 Share Posted January 7, 2010 I am trying to change the fuel separator on my 83 GL wagon. I can't seem to find a way to get to it. I can see where the three lines coming from the tank go into a rubber gasket, but I can't find a way to get to it. Also I removed the triangular plate, but all that is under is the filler neck and a fuel line not going to the separator. ANy suggestions? Thanks. Quote Link to comment Share on other sites More sharing options...
markjw Posted January 7, 2010 Share Posted January 7, 2010 The filter is forward of the rear,passenfer tire about 10 inchs. Inboard about 8 inch's. There,you will find a triangular plate secured with three 10mm bolts. On the plate will be the fuel pump and a filter. Also a filter in the engine room by the firewall.Drivers side. Quote Link to comment Share on other sites More sharing options...
wowzers Posted January 7, 2010 Author Share Posted January 7, 2010 Got it thanks a lot. Hopping this cures my sputtering problem. Quote Link to comment Share on other sites More sharing options...
wowzers Posted January 7, 2010 Author Share Posted January 7, 2010 Runs like a champ now. Thanks. Quote Link to comment Share on other sites More sharing options...
