Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
Sound from front left
#1
Posted 15 January 2010 - 08:59 AM
However I noticed if I turn my wheel to the left while moving like going around a turn or whatever it gets a little louder.. turning to the right it seems like something shifts and it's like a metal rubbing sound.
the only thing I know is when i went to check my brake pads way back in the spring time the brake pad back which I think is the anti squeal price was so rusted it just fell away would this be causing this?
#2
Posted 15 January 2010 - 09:35 AM
#3
Posted 15 January 2010 - 11:10 AM
I'd check the brake pads and also the axles to make sure nothing is rubbing.
I don't know who makes these pads but they have no bite at all only reason I did not change them when I did the rotors was because they still had like 60/70% life left.
And it's been a long time since I brought pads but do you get a new backing plate with the new pads?
#4
Posted 15 January 2010 - 12:18 PM
Personally, I find those damn anti-rattle shims cause more noise then they're supposed to fix. So I usually don't run them, and will just use some CRC disc brake quieter on the back of the pads where the caliper & pads touch.
#5
Posted 15 January 2010 - 12:25 PM
What are you referring to ask backing plate? The anti rattle shims? Some of the new pads have anti rattle shims/pads built onto the pads.
yeah the anti rattle shims
#6
Posted 16 January 2010 - 05:46 PM
#7
Posted 17 January 2010 - 07:54 PM
#8
Posted 20 January 2010 - 11:23 AM
#9
Posted 20 January 2010 - 12:19 PM
make sure the axle nut is installed and torqued correctly. Animproper axle nut/washers install will compromise the wheel bearing and eventually the hub splines where they engage the axle
#10
Posted 20 January 2010 - 04:55 PM
