soobme Posted February 8, 2004 Share Posted February 8, 2004 OK guys, I'm kicking around the "turboed carb EA81" idea (and I know that FI is "better", but NOT for me) and I was just wondrin' if any one out there is running a draw through sys. and could tell me what size carb they are using. I'm thinking of a webber IDA 44mm, or a 40mm. If I do it it will be a stock EA82 turbo, custom pluming, and stock comp. (8.5 I think) on an EA81 with '84 heads and an SPIF intake. Quote Link to comment Share on other sites More sharing options...
Hondasucks Posted February 8, 2004 Share Posted February 8, 2004 okay, first off, '84 heads have smaller valves than '85-88 EA81 heads do. (mechanical and hydraulic lifter engine difference) Plus, the SPFI intake is a lot more work than just "bolt on". But I'm sure you know that... you'll probably need to cut your hood and work a hood scoop on... but there are carbs out there that are "induction" approved... If in the 80s, they made turbo carbureted cars on production lines, I say it's all possible. Quote Link to comment Share on other sites More sharing options...
soobme Posted February 8, 2004 Author Share Posted February 8, 2004 I didn't know that the big valve heads didn't start till '85, I thought that they started in '84. Thank U;) If I do it, I know that it will need a big scoop to cover it, but I was thinking of just having a hole with the air cleaner sticking out:-p Quote Link to comment Share on other sites More sharing options...
