eventoday Posted January 17, 2010 Share Posted January 17, 2010 Hi, I have 01 outback. It has 220k miles. Recently while driving my battery, abs, and brake light came on. Within a minute they went off but the ABS light would turn on when I pushed the gas pedal and off when not pushed. Now I have had those 3 lights turn on, on another subaru and 20 minutes later the car died and the alternator had died. So I took the car to autozone and they tested the altenator. They said it was good. I noticed it showed 12.6 amps. I dorve the car for 2 days with the ABS light coming on and off. Then yester morning the car had no power. I didn't leave anything on. I jumped the car when I got back from work. I drove it for about an hour and no problems. When I returend home I turned it off and started it an hour later with no problems. This morning dead. Also the battery is new within 4 months. any ideas? thanks Jake Quote Link to comment Share on other sites More sharing options...
Durania Posted January 17, 2010 Share Posted January 17, 2010 My money is on the alternator, those things can be finnicky when they are on their way out. Quote Link to comment Share on other sites More sharing options...
edrach Posted January 17, 2010 Share Posted January 17, 2010 I'm with Durania also. By the way, 12.6 amps makes no sense. Your alternator should be capable of over 60 amps of output. But 12.6 volts indicates that the alternator is bad also; should be over 13 volts output. My Impreza shows 13.6 volts once it gets off idle and my Forester is at 14.1. Looks like an alternator problem to me; make sure the belt is sufficiently tight also. Lastly, get your battery on a charger; a discharged battery will deteriorate rapidly no matter how new it is. Quote Link to comment Share on other sites More sharing options...
eventoday Posted January 17, 2010 Author Share Posted January 17, 2010 Im sorry I meant volts. The guy at autozone said 12.6 was alright but I thought it was low. Why would there be no battery in the morning though. It seems like the alternator is doing enough to keep the car running? why would the battery discharge? just a thought before I go spend a $160. thanks again Jake Quote Link to comment Share on other sites More sharing options...
Blacky Posted January 17, 2010 Share Posted January 17, 2010 Could be the new battery is defective, have it checked. Quote Link to comment Share on other sites More sharing options...
Rooster2 Posted January 17, 2010 Share Posted January 17, 2010 Could well be a bad cell in the battery. I had that once. Car would start, but gauges gave crazy read outs, and warning lights kept going off, and the car ran poorly. All because of low battery voltage. Alternator should have an output of 14V, not a paltry 12.6V. Suggest getting both alternator and battery checked out. Maybe find a smarter guy at AZ, who knows that a12.6V read out is not good. Quote Link to comment Share on other sites More sharing options...
johnceggleston Posted January 17, 2010 Share Posted January 17, 2010 if the alt is not doing it's job the car runs off of the battery. i have also heard that a bad alt can kill even a new battery. Quote Link to comment Share on other sites More sharing options...
eventoday Posted January 17, 2010 Author Share Posted January 17, 2010 So I took the battery in to get tested. They said it was bad. So they gave me a new one under warranty. I put it in and the battery, brake and ABS lights came on right away. They seem to come on and off now. I checked all my connections and they are tight. ALternator? Quote Link to comment Share on other sites More sharing options...
Durania Posted January 17, 2010 Share Posted January 17, 2010 ALternator? Yes. Quote Link to comment Share on other sites More sharing options...
eventoday Posted January 17, 2010 Author Share Posted January 17, 2010 Ok, So I just went to a different auto parts sotre and had my alternator checked. This time it was reading 15.6v. They said the altenator is fine. Could this be some connection issue or a bad ground? thanks Jake Quote Link to comment Share on other sites More sharing options...
frag Posted January 17, 2010 Share Posted January 17, 2010 Ok,So I just went to a different auto parts sotre and had my alternator checked. This time it was reading 15.6v. They said the altenator is fine. Could this be some connection issue or a bad ground? thanks Jake I'm no alternator expert but I strongly beleive that 15,6 volt is too much. Something's wrong with your alt cause it's sometimes reading low and sometime reading high. I think it's time you buy a digital multimeter (cheap) and do a series of tests. Just connect the meter's leads at the battery posts when the alt is charging. Look for something closer to 14 volts. Quote Link to comment Share on other sites More sharing options...
Durania Posted January 17, 2010 Share Posted January 17, 2010 How about just going ahead and replacing it? That way it doesn't kick the bucket on you 70 miles from home and end up paying the tow bill on top of a new alternator. Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted January 17, 2010 Share Posted January 17, 2010 The alternator is bad. It wouldn't hurt to double check the cables and terminals for corrosion. If they're not shiny, clean them anyway. Quote Link to comment Share on other sites More sharing options...
Blacky Posted January 17, 2010 Share Posted January 17, 2010 Was the new battery fully charged when you bought it? Often they aren't. Quote Link to comment Share on other sites More sharing options...
edrach Posted January 17, 2010 Share Posted January 17, 2010 15.6 volts...bad regulator in your alternator. How much more information do you need? Stop going to AZ, obviously they're not hiring qualified people. Quote Link to comment Share on other sites More sharing options...
eventoday Posted January 17, 2010 Author Share Posted January 17, 2010 Thanks everybody I appreciate it. I put a new alternator in. No problems now everything works good. jake Quote Link to comment Share on other sites More sharing options...
edrach Posted January 18, 2010 Share Posted January 18, 2010 Thanks everybody I appreciate it. I put a new alternator in. No problems now everything works good. jake Glad everything is working for you. My apologies for my "less than tactful" last post. Quote Link to comment Share on other sites More sharing options...
lewisd Posted January 18, 2010 Share Posted January 18, 2010 just curious but are Subies finicky when it comes to alternators or will non-oe work as well? Quote Link to comment Share on other sites More sharing options...
Durania Posted January 18, 2010 Share Posted January 18, 2010 I put an auto zone reman one on my Brat when it died after work one day. Of course I didn't have much of a choice. I do try and stick to OEM on most items simply because there is a large difference in quality. Quote Link to comment Share on other sites More sharing options...
edrach Posted January 18, 2010 Share Posted January 18, 2010 I get most of my alternators from the pull a part yard. Bearings are easy to check before I pull it, then I install it in my car and if it checks good electrically I leave in my car and put my original one on the shelf as my spare. Occasionally, I will take one of my spares/cores to a local rebuilder who I trust. Either way I always have a spare on the shelf. I don't plan on spending $125+ for a rebuild from AZ or Schmucks. Quote Link to comment Share on other sites More sharing options...
Olnick Posted January 18, 2010 Share Posted January 18, 2010 ^ Amen, Brother! (And thanks, Ed.) Quote Link to comment Share on other sites More sharing options...
lewisd Posted January 19, 2010 Share Posted January 19, 2010 good advice, thanks! Quote Link to comment Share on other sites More sharing options...
destey Posted January 19, 2010 Share Posted January 19, 2010 I'm seeing a lot of people interchanging the words amps and volts. Quote Link to comment Share on other sites More sharing options...
OB99W Posted January 19, 2010 Share Posted January 19, 2010 I'm seeing a lot of people interchanging the words amps and volts. Watt? If the word ''Toyota'' doesn't scare you, there are a lot of excellent articles on automotive basics, including electrical topics, at http://www.autoshop101.com/ . Click on ''Technical Articles'' in the left column, and then on the article of interest on the page that links to. Quote Link to comment Share on other sites More sharing options...
