Speed Sensor Wiring
Kevin I have a FSM for the 83 and I'm sorry I do not see the VSS connecting to the ECM control unit.
The VSS is generated in the speedometer head unit.
Exits as a yellow with red tracer wire from terminal 45 on the speed-0 conntector.
It is used for the CC and the TC but does not appear to be an ECM input.
Could it be a late build date 83, making it an 84?
Hope someone has a better answer.
is the speedo itself working? tjhe sensor is in the instrument cluster, and is for things like cruise control
so if speedo isnt reading, check the cable. my 83 wagonhad cruise
on jims sedan, he accidentally pulled away the speedo cable while changing heater hose, thus resulting in no speedo, and a VSS code on the ecu
Checked for code in BAT auto
22 --- Ignition pulse system (1983 only)/Vehicle speed sensor or circuit or VLC solenoid valve or circuit. (1984 to 1988 carbureted)
checked mine from the board's repair manual
1983
22 --- Ignition Pulse System
1984
22--- Vehicle Speed Sensor (VSS) or Circuit
Is it an automatic?
Wasn't the change to hyd lifters made between 83 and 84?
On the automatic cars??
What colors are these wires ?
If nobody else comes to the rescue, I'll dig out my 84 FSM and see what it says.
Your welcome
