lmdew Posted January 24, 2010 Share Posted January 24, 2010 I got a 93 Sedan Auto Trans 152K. No rear drive. 1) Flushed the Fluid - No change 2) C-Duty is clean, FWD light comes on and I can blow air through it when energized 3) Clutches look good and when I put air to the pressure port on the clutch housing shaft they move freely. If I remove the C-Duty from the valve body, I can not blow air through it to make the clutch pack move. Should I be able to do that? Help, Trans is apart and I'd like to get to the root cause before I put it back together. Thanks, Larry Quote Link to comment Share on other sites More sharing options...
ericem Posted January 24, 2010 Share Posted January 24, 2010 (edited) Worked on this yesterday and had part transmissions. The tranny with no AWD had alot of slack meaning in the clutch drums you can compare how thick the clutches are. Ill post pics of what I am talking about. Also replaced the solenoid, and filter. See the gap between the clip? This one has no gap, well like extremely little. Edited January 24, 2010 by ericem Quote Link to comment Share on other sites More sharing options...
lmdew Posted January 24, 2010 Author Share Posted January 24, 2010 There is a little under an 1/8 of movement until they get to the stop. I got another one which has less play3/32 or so. I did not measure them but its a pretty good eye ball. Thanks Quote Link to comment Share on other sites More sharing options...
lmdew Posted January 24, 2010 Author Share Posted January 24, 2010 The clutch pack was it. I got a good one from CCR. Thanks CCR. All Done, just a little clean up and it will be up for Sale. 93 155K Turbo Sedan, White good rust free Colorado Car! Quote Link to comment Share on other sites More sharing options...
