coolant leak on Turbo
Which gasket do you mean?It looks like there is one between the water jacket(?)or what would be the bearing housing on a normal turbo and the exh. turbine housing.Im guessing its leaking there by the white residue under it on the base of the turbo.Are these readily available from subaru or elsewhere or could I make one?
