painting my XT
31 replies to this topic
#1 Markus56
Markus56
    Professional Hack
  • 783 posts
  • Havre, Montana
Posted 06 February 2010 - 08:34 PM
I got a wild hair and decided to paint my car. Went to the home depot and got some paint and clear coat
decided to only do one panel at a time, so i can still drive it during the week
sanded her down:
Posted Image
Posted Image
first coat
Posted Image
first coat done:
Posted Image
After that dried i put on a second coat of paint, and then 2 layers of clear coat.
More progress tomorrow!
#2 GeneralDisorder
GeneralDisorder
    Elite Master of the Subaru
  • 20,278 posts
  • Portland
Posted 06 February 2010 - 08:41 PM
Don't clear coat it - that will just peel off.
You should put around 5 to 6 coats of color on, then wet sand it with 600 then 1200 grit. Then buff it out with finishing compound. It will looks better and last longer than the clear coat.
Remember - light coats - but lots of them. Don't glob it on or it will take forever to dry.
Prep the surface with a D/A if you can get one or sand it real good by hand. Make sure the suface is very clean - use laqour thinner to clean up sanding dust, etc before you spray a panel.
There's nothing wrong with a rattle can job - just understand that it's going to last about 2 years give or take - the clear coat will make it look worse when it does start failing and makes it impossible to touch-up, color sand and refinish when it does start looking like poo in a year or two.
And watch out for big bugs - a good sized one will roll up that soft rattle can paint from your headlights to the winsheild if you hit em right :lol:
Edited by GeneralDisorder, 06 February 2010 - 08:44 PM.
#3 twilightprotege
twilightprotege
    New User
  • PipPip
  • 23 posts
  • Brisbane, Australia
Posted 06 February 2010 - 09:49 PM
follow this and enjoy - a very good step by step how to
http://autofix.com.a...og/archives/497
#4 wagaru
wagaru
    USMB Regular
  • PipPipPip
  • 60 posts
  • deep in the heart of...
Posted 06 February 2010 - 10:08 PM
you know i had good luck with wheel clear. seems harder than regular clear, from a rattle can. tru tru on the touch up thing though. if you plan on keeping it solid, you will need to touch up from time to time, and clear makes that step a bit more involved. plus for the clear to stick, you would have to wait for the paint to fully dry, id give it a week or 2, since its non catalyized, and then scuff it with a light grit paper or scotchbrite, and THEN apply the clear, or it will indeed fall right off. if you do clear, and need to do a touch up, you have to sand the area around the scratch then touch up and then RE clear to a body line, or even the whole panel, it really does add a level of complexity to the whole ordeal. tip for the year? avoid red rattle can, it fades REALLY fast, and when it does, it turns pink ;)
Edited by wagaru, 06 February 2010 - 10:10 PM.
#5 one eye
one eye
    I'm A Subaholic
  • 2,505 posts
  • Mt.Vernon Washington
Posted 06 February 2010 - 11:06 PM
That looks cool Yohn, Are you going to do yellow somewhere in there too?
Jeff
#6 derburger
derburger
    USMB Regular
  • PipPipPip
  • 79 posts
  • Central IL
Posted 06 February 2010 - 11:27 PM
Looks good so far... It'll probably look like my XT when done. Leaving the lower portions of the doors and quarter panels white, and painting the top of the front bumper would look cool. My XT was repainted single stage blue, it's easier to manage than a clear coated paint. Gotta have yellow in there somewhere!
Posted Image
#7 Markus56
Markus56
    Professional Hack
  • 783 posts
  • Havre, Montana
Posted 07 February 2010 - 01:19 AM
I am gonna paint the whole thing blue, except the hood, which will be flat black. Then i am considering having blue racing stripes on the hood.
I wanted to use clear coat, because it would prevent fading, but should i not use it?
btw, i'm using krylon paint
And for yellow, i had somthing like this in mind:
Posted Image
Edited by Markus56, 07 February 2010 - 01:32 AM.
#8 Markus56
Markus56
    Professional Hack
  • 783 posts
  • Havre, Montana
Posted 07 February 2010 - 10:43 PM
go some sanding done, but it was too cold and humid to paint. go saints!
#9 Scoobywagon
Scoobywagon
    Evil Genius (tm) for Hire
  • 1,044 posts
  • Bremerton-like
Posted 08 February 2010 - 10:08 AM
If you're doing it out of rattle cans, then GD has a point. Forget the clear.
#10 grossgary
grossgary
  • Gold Subscribers
  • 18,055 posts
  • West VA
Posted 08 February 2010 - 10:20 AM
any time estimates - like how long did it take to do one fender?
i have some before and after pictures of a guy i know that did this to his RX, i posted links to it here and on subaruxt.com. $64 paint job was the title of the thread on subaruxt.com.
i told him not too and it looked good, i was impressed. he was driving the car a couple years, not sure what happened to it after that. he never clear coated it as far as i know.
#11 MilesFox
MilesFox
    Catch this Fox!
  • 9,188 posts
  • Madison/Milwaukee, WI
Posted 08 February 2010 - 07:43 PM
i have been fine using middle grade spray paints. stay away from the 99 cent stuff as it will oxidize qiuckly.
krylon paints are ok, but will oxidize by 2 years, bu is not hard to do seasonal youchups. Krylon will be dissolved by gasoline, though, say, if you spill fuel when filling up.
rustoleum is best or an equivalent brand enamel paint. Takes longer to dry, but will be a tougher paint.
I have used clearcoat on one paint job out of 20 or better. I used it on rustoleum "metallic' blue to seal in all the little flakes. I used the cheapest cleargoat and it held up for several years.
if you are using a rustoleum grade glossy paint, clearcoat isnt really necessary.
if you want a primo paint job for cheap, do your hand at the rustoleum stuff, and then have the car clearcoated with professional grade materials.
if you are handy with spraying, you can get cheaper paint to look as good as better paint, but the paint job will last only as long as the paint you use.
my general rule of thumb is, the more paint smells like candy, the better it is
#12 Scoobywagon
Scoobywagon
  • 1,044 posts
  • Bremerton-like
Posted 08 February 2010 - 09:19 PM
The best rattle can paint I've EVER used is SEM. EXCELLENT stuff. Lays down almost as nicely as some single stage acrylics.
#13 Markus56
Markus56
    Professional Hack
  • 783 posts
  • Havre, Montana
Posted 09 February 2010 - 12:05 AM
Well, i just found out, that i am actually using rust-oleum. More specifically, rust-oleum painter's touch. I also found out today that i own an air powered paint sprayer.
#14 kingbobdole
kingbobdole
    Mr. XT-6
  • 1,629 posts
  • Longmont
Posted 09 February 2010 - 12:06 AM
I rustolem'd my XT a few years ago for about $40. Using the gallon cans and a harbor freight spray gun and stolen-from-my-father sanding materials... it was a great choice considering what my car looked like before.
Sanded and prep'd it decently, took about 20 hours for that.
Posted Image
Posted Image
Then sprayed about 5 coats on it. No clear.
Posted Image
Posted Image
Still looks ok if I wax it... I painted it in '06 before the Alcyone Dragon run and this was it at The Dragon last year.
Posted Image
#15 Markus56
Markus56
    Professional Hack
  • 783 posts
  • Havre, Montana
Posted 09 February 2010 - 11:18 PM
That is one sweet ride. I've been looking for a trunk lid with the spoiler thingy, but i haven't had any luck
I am going to return the spray paint and get a gallon of enamel
Edited by Markus56, 09 February 2010 - 11:20 PM.
#16 wagaru
wagaru
    USMB Regular
  • PipPipPip
  • 60 posts
Posted 11 February 2010 - 06:09 AM
that is the hottest xt i have ever seen 10 million points!:eek:
#17 kingbobdole
kingbobdole
    Mr. XT-6
  • 1,629 posts
  • Longmont
Posted 12 February 2010 - 01:26 AM
Thanks! It's really ugly up close... until you open the hood.:grin:
#18 CHIM
CHIM
    I think i can break that.
  • 366 posts
  • Oregon
Posted 12 February 2010 - 01:32 AM
There's not to many car's (in my opinion) that look good in yellow, but that looks pretty good.
I love the yellow the the baja's!
#19 xoomer
xoomer
    1000+ Super USER!
  • 1,139 posts
  • Burien
Posted 12 February 2010 - 10:56 AM
What ever happened to the $50 Dollar Paint job, I heard that it was a viable solution to paint issues.
#20 Markus56
Markus56
    Professional Hack
  • 783 posts
  • Havre, Montana
Posted 19 February 2010 - 10:16 PM
progress!
Posted Image
Posted Image
#21 kingbobdole
kingbobdole
    Mr. XT-6
  • 1,629 posts
  • Longmont
Posted 20 February 2010 - 12:30 AM
Looking good. Get the roof done then you can get a low side view shot and convince people it's totally done.:banana:
Also, join the XT board:grin:
#22 The Dude Abides
The Dude Abides
    WileE Coyote Super Genius
  • 2,912 posts
  • West Des Moines, IA
Posted 20 February 2010 - 12:48 AM
Whats your plan for sanding.
#23 Breeke
Breeke
    Eat, Live, Breath Subaru
  • 296 posts
  • Onalaska, WA
Posted 20 February 2010 - 09:19 PM
sand paper....:lol::lol:
#24 Markus56
Markus56
    Professional Hack
  • 783 posts
  • Havre, Montana
Posted 21 February 2010 - 10:23 PM
welp, i've got a belt sander with some 3 grit paper. That should smooth things up in no time at all
#25 Txakura
Txakura
    Not the Stig
  • 948 posts
  • Albion, WA
Posted 23 February 2010 - 01:27 AM
:lol:
:clap:
holy crap I laughed at that, is that like hand selected parking lot gravel with a sticky side out duct tape belt?
