djbroadus Posted February 10, 2004 Share Posted February 10, 2004 Ok so I been rwdriving it for a while now and I'm not sure that its the axles. Here are some symptons: Front end noise kinda sounds like I have swampers loudening with speed Noise goes away when I push on the brakes Stronger rubbing on corners and drifts a little Larger turning radius Quote Link to comment Share on other sites More sharing options...
junkyardgabe Posted February 10, 2004 Share Posted February 10, 2004 sounds like you stripped out a hub but if you've done this then you'll want to replace both hub and shaft if you can see the axle nut put it in 2wd put it in gear with it running and watch the axle nuts Quote Link to comment Share on other sites More sharing options...
