Trashwagon "EJ82" wiring harness, ecu
29 replies to this topic
#1 MilesFox
MilesFox
    Catch this Fox!
  • 10,686 posts
  • Madison/Milwaukee, WI
Posted 10 February 2004 - 05:25 AM
so i have this leganus with a 2.2 motor. well, i pulled it out to see how it would fit against a full time 5spd
the bottom studs line up, but the trans is offset to the motor that way. i compared the flywheel, and the holes are the same size and pattern, just farther apart. the center for the crank is the same size.
i removed the studs, stuck the flywheel on(no bolts) and lined up the input shaft.
i need to figure a way out to make an adapter plate, i found some pieces of hot rolled steel, have the idea to weld on some studs.
the holes between trans and motor are too close to make side by side bolts, i would like to drill and tap itf there is enough meat.
so far i can do the flywheel, if i can just figure out an adapter.
if all else fails, i can go with the ej 2wd auto just so i can do the swap, to have a reliable motor instead of some floppy carb
(87 gl-10 turbo (carbbed spfi block) wagon, half a 5 lug suspension)
#2 MilesFox
MilesFox
    Catch this Fox!
  • 10,686 posts
Posted 10 February 2004 - 05:26 PM
looks like im gonna have to find me a nifty chunk of aluminum, for now...
#3 mcbrat
mcbrat
    Brattitude Adjustment
  • Administrator
  • 11,185 posts
  • Central Iowa
Posted 10 February 2004 - 05:38 PM
Fox,
there's another thread out there, where someone is putting a Legacy motor and Ea82 trans into a Justy. He already has the spacer built, and has some pics.....
#4 MilesFox
MilesFox
    Catch this Fox!
  • 10,686 posts
Posted 10 February 2004 - 05:59 PM
i read a little on that last night with the search, but i disnt see any pics. i will look again
at least if i can see an example, it will give me an idea of what to do. so far the only example i had seen was one BRATSRUS had (uninstalled), it was one of 2, which i believe the other one CORKY had in ULTIMATE RX
#5 Qman
Qman
    Happiness is... no lag!!
  • Moderator
  • 11,119 posts
  • Sumner
Posted 10 February 2004 - 06:03 PM
Corky used all EJ gear. No adapter was used.
Jerry has the only adapter that I know of currently.
#6 subaru_guy
subaru_guy
    New User
  • PipPip
  • 10 posts
Posted 10 February 2004 - 06:59 PM
http://home.comcast....ID-1279235.html
That site has all sorts of nifty pictures of his installation and rollcage buildup.
#7 TomRhere
TomRhere
    Certified BRAT nut!!!
  • 4,600 posts
  • Hillsdale, Mi. USA
Posted 10 February 2004 - 08:48 PM
Was the guy doing that Rally Justy. I remember seeing the pics of the engine and adapter, had to go to his website though
#8 MilesFox
MilesFox
    Catch this Fox!
  • 10,686 posts
Posted 11 February 2004 - 09:30 AM
cool, i saw the pictures last night, and it looked very much like whatt i was thinking to do with steel and studs.
but the steel ide wont work, because with the aluminum i can have the depth for THREADED studs, and recessed bolts for the motor
i am going to look for aluminum today 15 inches wide by 12 inches tall. i will use whatever thickness is available, and use some of the cut out to have a flywheel spacer made.
i will work the adapter myself, and myoss feece has access to a BAND SAW, the spacer i will roufg out, drill the holes, and have a machinist turn it down gfor me, and cut the hole in the middle. i will give the machinist the spacer plate that came off the ej22 for dimensions. there is one around here that costs 50 bucks an hour. ut obviously thats worth it for an ej22 against my choice of 5spd (full time xt6, but eventually into trashwagon5, dual range)
i will put the ej in trashwagon6, leave the turbo mpfi harness there for now, then put the ej motor in trashwagon 5, after i have a turbo motor for 6
#9 MilesFox
MilesFox
    Catch this Fox!
  • 10,686 posts
Posted 11 February 2004 - 06:40 PM
ok now, i scored a chink of aluminum 15"x13" 3/8" thick. i have already drawn and traced out the templates for both the ej and ea bellhousings.
right now i have started to CUT with a JIGSAW. i found it cuts smoother if i gice a squirt of PB blaster.
i plan on having it cut, drilled, and tapped tonite. already got a 10mm 1.25 tap.
i found some nifty countersunk socket cap bolts, but they dont come in 1.25 threads. so i am going to have to be inventive here. i got some hex head bolts to start with, lets see what happens
#10 MilesFox
MilesFox
    Catch this Fox!
  • 10,686 posts
Posted 12 February 2004 - 12:39 AM
its all cut out. now i have it bolted to the motor
thge bolts i used were a 17mm head, so i had to grind recesses in the tranny bellhousing. i will be using original studs from the 2.2 and ea82 cause o wont find them in the hardware store
i will drill thru the plate till i strike meat on the motor where i can, tap it m10 1.25
i will drill and tap the the dowels, and use bolts with nuts.
there are 2 spots on the top of the ea tranny that can be drilled for bolts with nuts.
i need to get an 11/32" drill bit for the studs, tap. i will do that tomorrow.
the input shaft slides in as it is, with 3/8 thick aluminum, and the heads of the bolts. i will dtrim the corner on the bolts to allow for the studs
i may attempt a flywheel spacer, but first i will try without, may use the ej22 flexplate retainer. i will use that to drill out the flywheel, as a template, and maybe to brace the flywheel after its drilled
if i maintain the exact alignment woth the holes, they will be oblong, and the flywheel can still be used on an ea82 motor.
the legact and ea82 bolts are the same size for the fltwheel to crank, i will be using ea82's
as far as the bottom studs, no i did not align them with the ea trans. i tool them out of the ej22, put the ej in a bucket, and hung the trans from the hoist, and lined up the pilot bearing to the flywheel, which just fits on the crank snout in the back
#11 MilesFox
MilesFox
    Catch this Fox!
  • 10,686 posts
Posted 12 February 2004 - 06:29 PM
ok, now i got my 11/32" drill bit. my recesses are ground out on the trans bellhousing, just a little more work to mate. the bolts that hold the plate on, i trimmed a corner off each head, to make room for the bottom studs, less grinding on trans
the input shaft lines up bBEFORE the recesses, so now the only spacing will be 3/8. i am pretty sure i wont need a flywheel spacer as long as the starter engages
i will have it mocked up tonite, studs, thread locker. then i will drill the flywheel
#12 MilesFox
MilesFox
    Catch this Fox!
  • 10,686 posts
Posted 13 February 2004 - 02:35 AM
tranny now mates against plate. i installed a stud at the bottom, tapped the dowels for bolts, and drilled 2 holes on the top for bolts.
the bottom passenger side stud threads thru the plate thru the block. the other side i will have to use a bolt.
i removed the starter stud and treaded a ling stud thru to the block
now i have drilled out the flywheel, using the AT's flex plate retainer as a template. i had to work the holes a little with the DREMEL, but now all the bolts tread in, and the heads cover all of the hole..
i could keep going, but its late. tomorrow i will take a sanding disc to the flywheel, mount the clutch, and bolt up the tranny. from there i will mock up the starter, to see how the teeth engage, with 12 v.
so long as i secure the motor so it doesnt torque itself out of its bucket! (trans hung in the hoist)
hopefully i will get as far as pulling the crossmember, and installing the motor/trans form underneath(suspension mods at the same time)
so far i have $43.18 wrapped up in this project. 30 for the metal, and the rest for a tap, drill bit, and jigsaw blades(pair)
so now all the work has been done, as long as the starter lines up.
#13 MilesFox
MilesFox
    Catch this Fox!
  • 10,686 posts
Posted 13 February 2004 - 01:19 PM
ok, the starter is mounted. on the top hole, ihad to tap out for a 17mm bolt, since the hole i drilled missed some of the metal.
the bendix gear is hitting something, just clicks, so it looks as if i am going to grind away on the plate on the inside
#14 MilesFox
MilesFox
    Catch this Fox!
  • 10,686 posts
Posted 14 February 2004 - 05:43 PM
ok, now the motor cranks over. the bendix gear is *slightly* engaged like it is, but i am going to go with this till i get it running, since it now turns over
i am using a tock ea82 starter. suppose i could grind away the corners of the teeth on the bendix gear later on, since i have spare starters
#15 MilesFox
MilesFox
    Catch this Fox!
  • 10,686 posts
Posted 14 February 2004 - 09:55 PM
now i have the ENTIRE FRONT SUSPENSION, CROSSMEMBER out of the car. i also have the struts and knuckle out of the leganus
i took a few pics
www.warpthree.com/milesfox/ej22
#16 torxxx
torxxx
    I void warranties
  • 2,918 posts
  • Fairbanks
Posted 14 February 2004 - 10:03 PM
nice carpet job..
I wanna do that with mine when I find some light blue shag carpet
#17 MilesFox
MilesFox
    Catch this Fox!
  • 10,686 posts
Posted 14 February 2004 - 10:09 PM
its real easy, you pop the door [panel off.
and the top padded part and the door pocket are held on by screws
cut the carpet to fit, and install the pices, so the screws go thru the carpet. it will hold itself together
on the back doors, only the top and door handle will hold on, so i used some nylon zip ties on the bottom
#18 Hondasucks
Hondasucks
    Subaru Technician
  • 4,760 posts
  • Vancouver, WA
Posted 14 February 2004 - 10:14 PM
MAn, and I thought the front end on MY legacy was tweaked! Sheesh! Mine was straight in comparison! Nice work, Fox :-)
#19 MilesFox
MilesFox
    Catch this Fox!
  • 10,686 posts
Posted 15 February 2004 - 12:24 AM
oki, now i am doing my suspension, so far i have built up the crossmember with xt6 swaybar, and spare ea82 control arms that have been drilled out for the legacy ball joint.
#20 rguyver
rguyver
    USMB is life!
  • 218 posts
  • Kelowna B.C. Canada
Posted 15 February 2004 - 12:45 AM
hope to see pics of it running :D
this is the next mod. for my brat an EJ motor with a RX Hi Lo , i just hope the gears can handle it ;)
#21 bushbasher
bushbasher
    exhaust fume addict
  • 1,707 posts
  • Sooke B.C. Canada
Posted 15 February 2004 - 03:52 AM
lookin good. The fastest trashwagon yet?
#22 MilesFox
MilesFox
    Catch this Fox!
  • 10,686 posts
Posted 15 February 2004 - 06:05 AM
now i got as far as having the subframe built up, with motor and trans mounted. I will be using the SHIFTER from the CAR, on the 5spd full time, and the xt6's TRANNY MOUNT.
the motor mount holes are slotted and lined up so the dowels on the mounts go thru. i also used the ej22 mPOWER STEERING LINES connected to the EA82 RACK
i have found that i will be FORCED to use the XT6 KNUCKLE, ROTOR, to keep the parking brake style CALIPER. they are bolted to the LEGACY STRUT, and the strut has the EA82 CAP
the assembly is ready to slip under the car. the struts are mounted to the strut towers. i will install the motor/frame first. then connect the axles and ball joint.
the front will be using XT6 tierod ends
i still have yet to compare xt6 and legacy axles, but i need the 1-1/8" socket(yosh has it). the axles are the same length, i want to know if the splines are, because one of the xt6 axles has a torn boot. i will have xt6 on one side, and legacy on the other if they indeed do fit the same
Posted Image
STRUT
#23 myossfeece
myossfeece
    USMB is life!
  • 231 posts
  • UPinAsubaruRX, INDIANA
Posted 15 February 2004 - 06:36 PM
yeah we have the ea82 crossmember bolted up to the car with the ej22 motor bolted to the ea82 ft4wd 5spd. ej22+ea82=ej82!
Will definately be an rx killer now, but we will still drag race regularly just for sh!ts-n-giggles. The xt6 rear susp. is in tact in the anus of the wagon.
leg anus strutsin the front with xt knuckles, and swaybar and and ea82 strut caps.
Five lug all around. it is pimp.
#24 baccaruda
baccaruda
    YOUR FAVORITE MOD
  • Moderator
  • 6,950 posts
  • SpoVegas, WA
Posted 16 February 2004 - 01:18 AM
looks cool so far!
#25 MilesFox
MilesFox
    Catch this Fox!
  • 10,686 posts
Posted 16 February 2004 - 10:55 PM
tonight i messed around under the hood, since now ther is a motor there.
o connected the clutch cable. the 4wd vac lines are connected, but the wiring has a different plug. i need to swap the wiring from the other trannyv yet, now that i see,. the tranny ground wire is connected
i will need longer hose for the heater hose
i will need a linger throttle cable, the hashed turbo cable is too short, i will try the legacy cable. if that dont work, than an spfi or carb cable will do
i tried to mount the legacy radiator, but its too tall. but the xt6 radiator fits, once i change out the bottom rail for the alignment nipples.
i started to pull the harness from the legacy. uinder the hood i have the headlight front harness pulled to the relay box. i also have the dashboard out, for easy access
