Cleaning hazy yellow composite Headlights
9 replies to this topic
#1 SAButter
SAButter
    New User
  • Pip
  • 3 posts
Posted 03 March 2010 - 09:45 PM
this is a way to clean your composite headlights
#2 garwood1
garwood1
    New User
  • PipPip
  • 15 posts
  • Herefordshire UK
Posted 18 March 2010 - 05:36 AM
Amazing how many cars you see running around with totally opaque plastic headlamps....especially in places with high UV.
I typically use Blue Magic (or similar) metal polish, on a terry cloth rag - working VERY easily, so as not to get too carried away - stop and wipe away periodically, to make sure you haven't gone too far. Once happy with the finish, give a final polish with something like Autoglym Super Resin Polish, and finish off with something like Autoglym Extra Gloss Protection.
The results are staggering - the car looks new, and the improvement in headlight beam at night is amazing.
I once thought of starting a small business to do just headlight polishing !!
#3 xoomer
xoomer
    1000+ Super USER!
  • 1,139 posts
  • Burien, WA
Posted 21 April 2010 - 09:39 AM
My friend uses lacquer (sp?) thinner and it works well.
#4 AWDfreak
AWDfreak
    USMB is life!
  • 234 posts
  • SF Bay Area, CA (USA)
Posted 24 April 2010 - 04:51 AM
I personally use Meguiar's Headlight Restoration kit, it has everything you need (excluding a working drill). :)
It works great, but weird bump/lumps on the headlights will render the drill attachment useless :mad:
#5 SOOBOUTLAW
SOOBOUTLAW
    Junkyard Junkie
  • 536 posts
  • EVERETT
Posted 14 May 2010 - 10:47 PM
I used whitening toothpaste on my Legacy headlights, then sealed them with three shots of clear. Came out pretty nice. Much better illumination at night.
#6 Turbone
Turbone
    The Original Rob
  • Moderator
  • 12,203 posts
  • WA
Posted 14 May 2010 - 11:05 PM
My technique is to use my Makita cordless, a 3in buffer pad, a squirt bottle with water and a bottle of Griotts glass polish. It takes me 10min a light.
#7 paulbellefeuille
paulbellefeuille
    USMB Regular
  • PipPipPip
  • 49 posts
  • Kingston NH
Posted 17 May 2010 - 01:33 PM
I use a whitening toothpaste that is available at Dollar-type discount stores
It's "White" It's "Natural" but if I combine the two names I get a nasty note form the manufacturers legal department..no joke..
It work very very well..just apply a ribbon of the stuff to a dry cloth and gently rub.. the paste will do the work. Then follow it up with an orange-type cleaner to remove the residue.
Total cost is less than half a buck.. and you have enough paste to do 3 pairs of lights.
#8 northguy
northguy
    O.C.A.L. Life Member
  • 4,352 posts
  • Chugiak, AK
Posted 17 May 2010 - 07:30 PM
I believe there was a thread on this suggesting a new can of brake fluid.
#9 jseabolt
jseabolt
    USMB Regular
  • PipPipPip
  • 122 posts
  • Tri-Cities, TN.
Posted 19 May 2010 - 05:13 PM
I use Novus plastic polish. I bought this years ago to polish the windows on my Jeep's softop.
Funny. I've seen some cars with cloudy headlights and others without.
What causes this?
Material of the plastic? Would it matter if the car is garage kept or parked outside all the time?
I've had my Baja since 2002 and it stays inside my garage most of the time if I'm not driving it. The headlights look as great as the day I bought it.
Dad use to own a 2002 Jetta. He bought this car when it was about 2-3 years ago. Headlights were badly clouded. My wife's 2003 Nissan 350Z were clouded as well.
The headlights on my 1996 Ford Explorer are not clouded. I believe this car spent most of it's life outside in the weather because the tires were dry rotted when I got it.
So I'm not sure if sitting outside in the weather clouds headlights or not.
#10 heartless
heartless
    Do YOU Subaru?
  • 3,276 posts
  • North Central Wisconsin
Posted 23 May 2010 - 09:00 AM
some of it is the composition of the plastic, some of it is weather related.
my '90 Legacy had the yellowed, cloudy looking lenses - I went the way of a little more work, but outstanding results - used the fine to ultra fine wetsand method to remove the yellowed layer and clean/polish the surface of the lens - then a good quality plastic polish to seal it - the results are incredible!
There are many ways of doing this job - choose the one that works for you.
