moosens Posted March 15, 2010 Share Posted March 15, 2010 You ALWAYS get chick that can weld?? Our HERO !!!!!!! Copies ??...how much for copies???? The fab,not the girl. :-\ Quote Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted March 15, 2010 Share Posted March 15, 2010 (edited) I like what your doin here, zzzzzz whats the finished specs from stock? like overall lift? wheelbase over stock ? what tranny you runnin? any Transfercase? also what did you like about the wagon and what are you going to change on this sedan ?? axles which ones STI? and could you put a mike or caliper on one and tell me the diameter of shaft at midpoint, thank You Edited March 15, 2010 by Scott in Bellingham detail Quote Link to comment Share on other sites More sharing options...
Subafreak Posted March 15, 2010 Author Share Posted March 15, 2010 Lol, same chick Paul. We're on and off but she never passes up a chance to do some fabricating. Scott. I,m not sure about overall hight (I should remember to measure these things befor i start) I know the lift blocks are about 6 1/2 inches with another 1" in the struts. I will measure the wheel base after we get it all together again. This will basicly be the same drivetrain as the wagon. Will be using a subaru 5speed with welded center diff and a sammy T-case. Will be getting a reduction T-case from RockyRoad just havnt decided on what reduction to go with yet. With the 33" and the stock t-case it's on road manners were very good but it could still use a bit in the low range department. So with moving up to the 35"s i think im gonna go with the super crawler reduction gears, just hoping it doesnt rev to high on the highway. One thing that was troublesome on the wagon was the T-case position, it just hung to low. So that will be getting moved up into the body as far as we can. We will also be changing the front suspension and lift around. Whats in the wagon works and has proved to be very solid, but it's alot of metal and makes servicing the front diff imposible and makes a mess when you change the oil. Also we will be putting another R-180 diff in the front and changing the spindals to SVX ones, so at least the brakes will match a little better and we can have the same wheel bolt pattern front and rear. And the longer SVX axles should allow us to push the front track a little wider and help increase the turning radius with out the tires hitting. Will also be using STI rear struts in the front for longer travel, not so much for extension but a bit more compression with out hitting the bump stops. Traveling at speed down a potholed road in the wagon ussualy led to bottoming out the front suspension. As for those front axles, the top one is the STI axle and i will get some specs for ya next time im in the shop. Quote Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted March 16, 2010 Share Posted March 16, 2010 did some measurin Legacy and EA82 front axle .880 Dia Legacy and EA82 Rear Axle .840 Dia Nissan 720 front axles 1.10 Dia Tpyota 2wd pickup rear 1.275 Dia Quote Link to comment Share on other sites More sharing options...
Subafreak Posted August 22, 2011 Author Share Posted August 22, 2011 Wow. I can't belive it's been that long since I posted or really did any work on this thing. Either way I brought it in tonight and started going at it again. Quote Link to comment Share on other sites More sharing options...
Uberoo Posted August 22, 2011 Share Posted August 22, 2011 why does the output or input of the transfercase have that ring around it? Quote Link to comment Share on other sites More sharing options...
Subafreak Posted August 23, 2011 Author Share Posted August 23, 2011 An excellent question. It's the disc for the t-case mounted e-brake. I just havent mounted the caliper yet. Quote Link to comment Share on other sites More sharing options...
987687 Posted August 23, 2011 Share Posted August 23, 2011 An excellent question. It's the disc for the t-case mounted e-brake. I just havent mounted the caliper yet. Cool! Kind of like old subarus that had the brakes on the transmission side rather than in the hubs. Quote Link to comment Share on other sites More sharing options...
True2Blue Posted August 23, 2011 Share Posted August 23, 2011 subarus on here keep gettin bigger and bigger.. ill be tuned in Quote Link to comment Share on other sites More sharing options...
Subafreak Posted August 23, 2011 Author Share Posted August 23, 2011 Cool! Kind of like old subarus that had the brakes on the transmission side rather than in the hubs. Pretty much the same idea yeah. It was pretty cheap and now I know why, I gotta modify a little just to make it work the way it is supposed to. :/ This time around I built the t-case brakets right into the subframe of the car with extra rienforcments. The t-case mounts are old jeep control arms, figure there good enough to hold a front end in they should work for a t-case. I still gotta tie em together with a wrap around skid plate support so it shouldn't be going any where. Quote Link to comment Share on other sites More sharing options...
Subafreak Posted August 23, 2011 Author Share Posted August 23, 2011 subarus on here keep gettin bigger and bigger.. ill be tuned in Hell yeah! Whats the point in doing it again if your not gonna make it bigger and better? It'd like evolution. Quote Link to comment Share on other sites More sharing options...
81EA81 Posted August 24, 2011 Share Posted August 24, 2011 Subscribed! Epic shop by the way. Quote Link to comment Share on other sites More sharing options...
Subafreak Posted August 24, 2011 Author Share Posted August 24, 2011 Subscribed! Epic shop by the way. Thanks. I wish it was mine, I would make alot faster progress on all my projects. But at least having acess to it is good enough. Quote Link to comment Share on other sites More sharing options...
Txakura Posted September 1, 2011 Share Posted September 1, 2011 whoa, I got to hang out here more often. pretty serious stuff Quote Link to comment Share on other sites More sharing options...
tails878 Posted September 13, 2011 Share Posted September 13, 2011 i love it looks great little wierd with the strut hope you didnt burn the oil but its guna look super sick when your done i cant wait to see! check out the one i just finished up http://www.cardomain.com/ride/3937241/1995-subaru-legacy-l-wagon-4d Quote Link to comment Share on other sites More sharing options...
Subafreak Posted October 7, 2011 Author Share Posted October 7, 2011 Favorite weapon: saws all. Finally got around to cutting this side out since I finally got a set of 35s for it. Pretending it's at new ride hight. Got a killer deal on these off good old craigslist. Good motivation to get my rump roast in gear and start working on the frontend. Quote Link to comment Share on other sites More sharing options...
newsoobdude Posted October 7, 2011 Share Posted October 7, 2011 Lookin good. Keep us posted and moar pictars!!!! Quote Link to comment Share on other sites More sharing options...
Numbchux Posted October 10, 2011 Share Posted October 10, 2011 heh heh heh.....Cool! Quote Link to comment Share on other sites More sharing options...
ezapar Posted October 10, 2011 Share Posted October 10, 2011 First off, that thing looks baddass. But I have a couple of questions: *Does welding stuff to the struts mess with the gasses inside the strut by heating them up? *The final pic shows your axle angle to be sooooooper downward. Is that max flex, or are they expected to flex more? Quote Link to comment Share on other sites More sharing options...
Subafreak Posted October 11, 2011 Author Share Posted October 11, 2011 Thanks. To answer the questions: I'm sure the welding on the struts isn't great for them but they've been working great the whole time they were on the wagon and there not leaking by yet, not externally anyway. Lol. Figure when they do get really bad we will come up with a more permanent serviceable solution. As for the rear axle position, the suspension is not settled in the picture I had just set it down from being in the air. So it will sit a bit more level than that. You can check back on the monsterwagon thread to see how this set up works off-road. Nothing really different in the rear suspension. It's the frontend that's gonna be getting a makeover. Quote Link to comment Share on other sites More sharing options...
smackvt Posted February 20, 2012 Share Posted February 20, 2012 I can't Waite for the front end make over will you be moving the front sub forward? This thing looks freakingawsome I want one ... Time to start getting pumped up about wheeling for the season not much of a winter to speak of .. Quote Link to comment Share on other sites More sharing options...
Subafreak Posted September 6, 2012 Author Share Posted September 6, 2012 Oh yeah, I almost forgot I was working on a lifted Subaru. Dragged this thing outta the weeds tonight and got at it again. I'm at a point where this is my new priority so hopefully we will be seeing some serious progress in a timely manner. Tonight I worked on setting up the t-case e-brake and getting some driveshafts in it so I can figure out all my clearances and start getting a floor back in it befor any creatures try to move in. The temporary main shaft in place. A few of the rear shaft and e-brake set up. Thats all I got for tonight. Stay tuned. Quote Link to comment Share on other sites More sharing options...
branbikenut1 Posted September 7, 2012 Share Posted September 7, 2012 If i seen and read right you are running dual t-cases? how do those work together? Quote Link to comment Share on other sites More sharing options...
Subafreak Posted September 7, 2012 Author Share Posted September 7, 2012 Hmm.....no just one t-case on this one. Quote Link to comment Share on other sites More sharing options...
smackvt Posted September 8, 2012 Share Posted September 8, 2012 Sweet this might be the motivation I need to get mine going found a case with 6.5x1 low range .. still running a broke hi low Quote Link to comment Share on other sites More sharing options...
