*..Doing the disk brake convert..?*
6 replies to this topic
#1 bakerman1
bakerman1
    USMB Regular
  • 128 posts
  • Ashland
Posted 12 February 2004 - 12:21 AM
I have an 84 Brat and am doing the disk brake conversion in the rear. I'm heading down to the local salvage yard and need to know what years are the right cars to look at. I know I have to find turbo models cause that is what had the disk brakes, but need to know what years will work. Thanks for you answers.
Ken
#2 ShawnW
ShawnW
    Subaru Master Technician
  • Administrator
  • 12,952 posts
  • Denver, Colorado
Posted 12 February 2004 - 12:23 AM
Our "Knowledge base" is called the USRM. The button is found at the top of all the board screens.
The article you need is here.
http://usmb.net/repa...98.01552686.art
#3 MilesFox
MilesFox
    Catch this Fox!
  • 10,686 posts
  • Madison/Milwaukee, WI
Posted 12 February 2004 - 12:24 AM
any disc brake will work.
you can swap min ea82 drums too, at least they are bigger
you can also esilt modify a whole ea82 trailing arm to the brat, for example if a bearing was bad, and ea82s are more available
2wd discs will not fit a 4wd altogether, but the ROTORS and CALIPERS will fit the same. the hub is different, but unboltable from the rotor
#4 junkyardgabe
junkyardgabe
    WRX Goal Accomplished!
  • 558 posts
  • Lisbon Falls
Any year ea81 or ea82 turbo will work as long as it is the 4 bolt lug pattern
#5 bakerman1
bakerman1
    USMB Regular
  • 128 posts
  • Ashland
Posted 12 February 2004 - 12:34 AM
Thanks for the replies.........you guys are dang quick
Ken :D
#6 ShawnW
ShawnW
  • Administrator
  • 12,952 posts
  • Denver, Colorado
Posted 12 February 2004 - 12:35 AM
ea81 turbo cars have drum brakes unless converted.
#7 junkyardgabe
junkyardgabe
  • 558 posts
  • Lisbon Falls
Posted 12 February 2004 - 12:46 AM
Yeah but I am sure he knows the difference between drum breaks and discs.
