Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
So. California EA82 Wheeler
#101
Posted 25 November 2011 - 09:26 PM
#102
Posted 26 November 2011 - 12:02 PM
#103
Posted 26 November 2011 - 12:08 PM
#104
Posted 29 November 2011 - 10:17 PM
Waiting a sponge bath and 2.5 liters of fury!! And a little hole to fit the new heater/ac under the stock dash
View from inside
The 01 Impreza hvac unit. I had to tab both halves together then mount to car.
Quick little mount for the new fuse block
All the bits on the rack
#105
Posted 30 November 2011 - 04:36 PM
Have you considered tearing out the carpet and spraying it with bedliner or rubberizer?
And what're you going with for a clutch? Can you use the clutch for the newer motor, or are ya gonna hafta use a clutch designed for the d/r trans?
#106
Posted 30 November 2011 - 05:51 PM
As far as clutch I have to use what the d/r will allow although I've heard a clutch from an xt-6 model would be better for the new motor.....I dont know much about that but if someone has some good intel, please do share.
#107
Posted 30 November 2011 - 08:02 PM
Anza-Borrego State Park
Little water
Little mud
#108
Posted 30 November 2011 - 09:37 PM
I have tossed around the idea of doing some type of truck bedliner stuff in place of the carpet but it is not on the current to do list.
Yeah, xt6 clutch is the way to go, but from what I've researched, the replament models you get from oreilly or carquest or napa actually don't have very much clamping pressure for some reason. The one you want is the oem replacement from the dealer. However, they're really fjdjsjsl expensive. Like $350 for the full kit.
One glimmer of hope is that apparently Exedy now makes one, and I think of all places Amazon has the best deal at like $120.
I've got an EJ22 in my GLW, and when I'm in 4low and doing some serious offroading, my clutch does start slipping a lot, and after a bit it starts smoking and slipping badly. And that's just with a 140hp motor. You might ask Randy in Bozeman what he uses. Roostema something is his username.
#109
Posted 01 December 2011 - 10:58 PM
Tied in rear diff bar to trailing arm pivot beam
Plate work to hard corner of unibody
#110
Posted 03 December 2011 - 09:23 PM
All the brackets I had to make for the hvac and fuse block
#111
Posted 04 December 2011 - 08:52 AM
#112
Posted 05 December 2011 - 12:05 PM
Through firewall
#113
Posted 05 December 2011 - 12:33 PM
#114
Posted 05 December 2011 - 12:40 PM
good work interesting thread
Thanks
Almost forgot a pic of the 2.5!
#115
Posted 05 December 2011 - 04:05 PM
#116
Posted 05 December 2011 - 04:13 PM
So what's going on in the lift with this 'ol gl?
Do you have a writeup on what you finally ended up going with on the lift?
I just saw that solid rear bar in these last couple posts and it made me wonder what the final design was on this one..
Nice job with the old-school dude!!
Edited by superu, 05 December 2011 - 04:17 PM.
#117
Posted 08 December 2011 - 09:31 PM
without dash
With dash carcass fitted
#118
Posted 01 January 2012 - 07:23 PM
#119
Posted 06 January 2012 - 10:35 AM
I also got a chance to work on it again. I ran the engine bay harness and mounted the fuse block and the windsheild washer fluid bottle.
Harness
Fuse block, tight fitting with battery!
Harness ran along drv framerail
Washer fluid botttle
#120
Posted 09 January 2012 - 10:37 PM
#121
Posted 20 January 2012 - 12:15 PM
#122
Posted 22 January 2012 - 11:55 PM
Widdled out this bad boy saturday
#123
Posted 23 January 2012 - 10:16 PM
1) Through my readings, I've found that the space between the engine bell housing and the transmission bell housing should be 0.5" to accomodate the clutch differences between the stepped EA82 stuff and the EJ stuff. How thick is yours? It looks like 3/4". Any reason for that, or am I all buggly eyed?
2) Do you plan to shim the engine mounts at slightly more angle than is found on the EA82 crossmember so they won't tear? There are tons of threads on this. I have a few tapered aluminium leaf-spring shims which should be perfect for this. They're a wedge from about 1/4" to 0" and 2.75"x4" and a hole in the middle. I'm sure you're familiar.
Also, what was your process to make the plate? I'm buying one, as I don't have great shop to do that sort of fabrication in, even though I'd do it if I had the right tools (sharpie & cardboard?)
I can't wait to hear how your engine runs. I've finished cutting down my '99 impreza harness and all I need is a fuel pump and adapter plate. If you need any of the a/c stuff from the 99, I still have all of it and can cut a good deal.
Best,
SK
Edited by kanurys, 23 January 2012 - 10:27 PM.
#124
Posted 24 January 2012 - 02:54 PM
Makin progress
That's sweet K, Which gearbox is that? Is that an EA dual range 4x4? The front cases look strangly similar to an EJ AWD gearbox.
Nice work on the wheeler, it's gunna rock your work with the 2.5 in front of it!!!
#125
Posted 24 January 2012 - 10:52 PM
looks very nice. I have two questions:
Best,
SK
Thanks! Its definetly a labor of love.
(1)The plate I made is actually .5'', I did at one point do all the proper measuring and it should actually be some where around 14.5mm-15mm thick (dont remember the exact number) But from what I've read 99.9% of the folks doing this run a .5'' plate. Im pretty sure the difference can be made up in the clutch cable adjustment. I started out with a $70 piece of 6061 aluminum at 17''x14'', now its only worth like 3 bucks in scrap
(2)As far as the motor mounts I guess I never caught onto why they would tear but what you said makes sense. I will just fix it like I did my trans mount. Im gonna set the motor then just weld a piece of strap from plate to plate on the motor mount itself. This will not allow the mount to move at all. I know this will dramatically increase the vibrations from the motor into the chassis but thats how I do it on race cars. If its too much for a daily driver then I will just mimic the way the mounts already have the hard stop just a bit closer so they dont allow the motor to jump when they stretch.
I think I have all of the a/c stuff I need but if I dont I will see if you do. I really cant wait for this to be done Ive been missing out on too many wheeling trips. The next real hurdle I have is to make all new a/c, heater ducting. Not gonna be fun. A little at a time I guess.
