requested! Pictures of the EA82t/TD04 Turbo
32 replies to this topic
#26 Turbone
Turbone
    The Original Rob
  • Moderator
  • 12,188 posts
  • WA
Posted 30 June 2013 - 08:18 PM
Small update:
Running 20PSI now.....this is insane!
Much much smoother spool @20psi with the TD04, engine runs better when boosting.
IAT is steady at 40* celcius.
As long as it lasts, I am planning on a dynorun soon....
to be contiued  :)
Get it on the dyno real quick, cause its not going to last more than several thousand more miles (maybe).
:popcorn:
#27 hyfly
hyfly
    New User
  • PipPip
  • 18 posts
  • Netherlands
Posted 02 July 2013 - 04:57 AM
Are you running an EA82T on 20PSI?
Dude...you are either very brave or completely insane...or both? :D
It's all about cooling guys....thats all sorted.
Now we have to see what the limit of the internals will be  ;)
21st is the dynorun planned  :D
#28 hyfly
hyfly
    New User
  • PipPip
  • 18 posts
  • Netherlands
Posted 08 July 2013 - 07:12 AM
20th of july there will be a dyno run!
#29 hyfly
hyfly
    New User
  • PipPip
  • 18 posts
  • Netherlands
Posted 21 August 2013 - 09:41 AM
Broke the gearbox....
Mega squirt Flatshift....
where it went wrong... ^_^
This came out of the gearbox after draining the oil
Some people call it "a problem"....I call it Torque.... :D
#30 Turbone
Turbone
    The Original Rob
  • Moderator
  • 12,188 posts
  • WA
Posted 21 August 2013 - 10:07 AM
Dont feel bad, I went thru 2 of them before upgrading.
Wheres the dyno results?
#31 hyfly
hyfly
    New User
  • PipPip
  • 18 posts
  • Netherlands
Posted 21 August 2013 - 11:51 AM
Mate, didn't went on the dyno.....
Had surgery 2 days before, had a blocked caliper, AND! A troubleshooting crank sensor, there was no time left to fix it unfortunately...
Im trying to get a Porsche 914 gearbox at the moment for a relatively quick swap, and good upgrade for now!
#32 -tombba-
-tombba-
    USMB Regular
  • 230 posts
  • Finland
Posted 03 December 2013 - 01:22 PM
Nice EA82T setup ou got there mate !
Just curious if you could share the megasquirt files and version of the megasquirt ? I'm going to install one to my engine next spring (hopefully) ad would appreciate any base maps to get started with. I do have pretty similar setup than you so it would hopefuly get me started and away to the proper tune up and save some time not configuring it all up from scratch. Since we have the european model engines (I assume you have it too in netherland) the megsquirt tune up files would be much closer than the USA versions available.
#33 hyfly
hyfly
    New User
  • PipPip
  • 18 posts
  • Netherlands
Posted 09 December 2013 - 03:25 AM
Hi Tombba,
send an email to stefanhoogvliet AT hotmail.com and I can send you the tune.
Beware of the E85! and the 1.4bar boost setting!
cheers Stefan
For the update: I bought a strengthened beetle gearbox to do an easy swap, but its winter now, so to damn cold to play with the car.
