1999 2.2L into 2001 Outback?
10 replies to this topic
#1 etc
etc
    USMB is life!
  • 207 posts
  • Maryland
Posted 19 April 2010 - 07:27 PM
I am thinking about taking an engine from wrecked 1999 Impreza with 2.2L (37K miles) and putting it into a 2001 Outback with a blown 2.5L, which needs an engine.
Any problems with this swap?
Edited by etc, 21 April 2010 - 03:22 PM.
#2 Rooster2
Rooster2
    Subaru Master
  • 2,865 posts
  • Indianapolis
Posted 19 April 2010 - 09:34 PM
Others smarter than me can tell you if it is an ez swap or not.
Surprised the owner wants $800 for what is a 11 year old parts car. For what it is worth, in my opinion, he is about $500 too high, but I bet you already realize that.
#3 etc
etc
    USMB is life!
  • 207 posts
  • Maryland
Posted 19 April 2010 - 09:49 PM
I thought so too, but OTOH, the engine and the tranny are supposedly pretty low-mile, it's not often that you see under 40K on that year.
#4 grossgary
grossgary
    Elite Master of the Subaru
  • Gold Subscribers
  • 17,909 posts
  • West VA
Posted 20 April 2010 - 08:52 AM
Low mileage is cool but there is a bit of novelty attached to it when speaking of older cars. I have better experience with average mileage engines that were regularly driven and maintained (harder to determine though). There's a theoretical side to older engines (cars) not being used often, driven much or sitting for long periods of time. Contaminants can sit for extended periods and gaskets/seals I don't think hold us as well either, can they dry out or...?
That being said I'd buy this one if it was needed $800 isn't a bad engine price for the range of vehicles this can be placed in.
#5 etc
etc
    USMB is life!
  • 207 posts
  • Maryland
Posted 20 April 2010 - 01:05 PM
Well, it comes with engine and tranny...
#6 etc
etc
    USMB is life!
  • 207 posts
  • Maryland
Posted 21 April 2010 - 03:23 PM
Opinions?
#7 grossgary
grossgary
  • Gold Subscribers
  • 17,909 posts
  • West VA
Posted 21 April 2010 - 07:25 PM
Oh I'm sorry - you mean if it will actually work? Yes *this* (not most though) EJ22, if it is indeed a Phase II EJ22 will swap into a 2001 EJ25.
The transmission will be a different gear ratio most likely - probably a 4.11 while the other will be a 4.44. Transmissions will still likely be interchangeable though.
As for the engine most of the time (so i thought, read later) you'll need to swap the 01 timing components (cam sprockets and crank sprocket) onto the Ej22. Some have said you don't always have to or there are two different styles, but I haven't seen that yet personally. basically the timing is different so you want the existing ECU to "see" the same info as the original engine - just transfer the stuff over.
#8 Blacky
Blacky
    New User
  • PipPip
  • 27 posts
  • Lac Sainte Marie
Posted 21 April 2010 - 07:29 PM
If it is a different gear ratio you will need to swap the rear differential as well, just in case you didn't know that already.
#9 johnceggleston
johnceggleston
    Lite Master of the Subaru
  • 5,595 posts
  • Virginia
Posted 21 April 2010 - 07:56 PM
if the 99 2.2 trans is not a phase 2 trans it will not swap. if the trans electrical connector matches it swap go.
i can't remember when the 2.2 auto trans went to phase 2.
#10 eppoh
eppoh
    Subaru Fanatic!
  • 381 posts
  • So central Texas
Posted 22 April 2010 - 11:59 AM
I'm pretty sure the 2.2 went to phase 2 in 99.
800 dollars for a good low mileage engine is a fair price based on what I found when looking for one myself. Just figure in all new belts since they are over 10 years old.
Has the owner or can you do a leak down test on the cylinders?
#11 msmithmmx
msmithmmx
    Subaru Nut
  • 647 posts
  • West Grove
Posted 24 April 2010 - 06:01 AM
I do not think those electrical connectors will match up. You need to check this, if they don't its not worth the time to try and make it work. 800 is way to much for a parts car. I would go 350 max. Remeber you still have another 100 in a tow.
