I have a ea82 sedan, and i was thinking about getting some different springs in the rear 1. to stiffen it up and 2. because both shocks are already blown in the rear so I might as well replace it with something better.
Probably just going to get wagon struts (are they any stiffer is my question)
or put rx-7 springs on it which a buddy did and that stiffened it up quite a bit.
-jeff
Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
wagon springs stiffer than sedan springs?
Started by
diamondjumper
, May 10 2010 03:01 PM
5 replies to this topic
#1
Posted 10 May 2010 - 03:01 PM
#2
Posted 10 May 2010 - 10:41 PM
yes, wagon springs are stiffer.
An alternative is to buy new struts, flip your old sturts lower spring mount over and slide it on as a spacer below the new spring seat and then use you're existing springs, or stiffer ones.
You'll get about an inch lift and more preload. way more if you use wagon springs.
#3
Posted 10 May 2010 - 11:24 PM
ok good to hear
My pull a part has tons of wagons with the rear struts, they can just sometimes be a pain to take the two top bolts off I am realizing. Is there any difference between 2 and 4wd springs? or can I just use the overabundance of 2wd struts?
thanks,
Jeff
thanks,
Jeff
#4
Posted 11 May 2010 - 10:05 AM
FWD rear struts are about two inches longer. But there springs are way softer.
FWD struts with 4wd wagon springs yields a good tall stiff ride that isn't TOO stiff. Flip an extra perch under the spring and you will get even more, but at that point it will be damn near solid.
#5
Posted 03 June 2010 - 04:26 PM
This is what I'm running on my lifted wagon and Need just a little more stiffer springs. I think I'm going to have some made up. I figure with the added weight of my bumpers/subframe, my payload is sacrificed significantly. If my car is EMPTY it rides perfect. After adding a highlift jack, spare tire, couple straps, shovel, tools, and a few spare parts, I am OVERLOADED.....
#6
Posted 04 June 2010 - 11:17 AM
I got some ea82 wagon springs on my wagon (ea81) to trade you for the sedan springs! Its my dd so it would have to be a quick swap.
