EA81 - I want to add Power Steering to my BRAT
16 replies to this topic
#1 dec0y13
dec0y13
    USMB Regular
  • PipPipPip
  • 81 posts
  • SE Idaho Pocatello
Posted 11 May 2010 - 10:49 AM
OK I have a 86' Gen 2 brat. I am jealous because my buddy got an 82' and his has power steering...and mine does not (sigh)
OK so, How hard is it to add power steering to a model that does not have it??
Can I buy the pump and hoses off a wagon some where?
Is there some kind of sensor that controls it?
Do I need the full knuckles and linkage?
I have not had the opportunity to crawl under my buddies Brat yet, so all I can see is the pump, bracket and hoses, I'm sure there is a hydrolic piston somewhere.
is there a link w/ pics anywhere??
#2 baccaruda
baccaruda
    YOUR FAVORITE MOD
  • Moderator
  • 6,950 posts
  • SpoVegas, WA
Posted 11 May 2010 - 10:52 AM
Hi, welcome to USMB!
The power steering swap has been done many times and is simple.
Let me show you a couple of things about the board - first, at the bottom of any topic's page, you can see related posts - they may be for-sale posts but check them out in case they have a list or a link to one.
Second, give our search a try. It doesn't like words of 3 characters or less so try "power steering swap EA81" but not "add power steering to EA81."
Good luck!
#3 dec0y13
dec0y13
    USMB Regular
  • PipPipPip
  • 81 posts
Posted 11 May 2010 - 11:01 AM
My bad, should have done a search on that one.
#4 GeneralDisorder
GeneralDisorder
    Elite Master of the Subaru
  • 21,704 posts
  • Portland
Posted 11 May 2010 - 11:30 AM
In addition to the search - your friend's Brat did not come with power steering so you might just take a look at his to see what they did to convert it.
You will need an entire engine cross-member from a power steering equipped EA81. Not the easiest thing to find in some parts of the country.
#5 Yo'J
Yo'J
    Certified Subaru Nut
  • 833 posts
  • seattle
Posted 11 May 2010 - 12:03 PM
If you have all the pieces for the power rack and cant get the crossmember off (like being stuck at pull-a-part), you can drill out the spot welds off the lower plate on your existing crossmember to remove the plate and drill the required holes for the new power rack, just bolt it back on when done and dont over drill. You will need all the parts from the power rack though and the rubber grommets as well. If you closely look and compare your friends crossmember and yours, you will see what I mean.
#6 Mr. Brat
Mr. Brat
    PNW best BRAT
  • 326 posts
  • Graham, WA
Posted 11 May 2010 - 01:37 PM
I have a pump I can sell.
#7 bheinen74
bheinen74
    Banned
  • Banned
  • Pip
  • 0 posts
  • central Iowa
Posted 11 May 2010 - 01:56 PM
like said, power steering can be added to any car. If you want it to work, you need the entire front rack, crossmember, as the racks are different from non-ps to the PS model.
If you have the rack and all parts, go for it. BTW good luck
#8 carfreak85
carfreak85
    Temple of Fuji
  • 5,247 posts
  • Cascadia
Posted 11 May 2010 - 03:28 PM
I have all the parts needed to swap over to PS, if anyone is interested.
Hard lines
rack
X-member
rubber grommets
hardware
pump/tensioner bracket
#9 dec0y13
dec0y13
    USMB Regular
  • PipPipPip
  • 81 posts
Posted 11 May 2010 - 05:03 PM
OK carfreak. what's it gonna cost me shipped?? I think I can get it at the junk yard here, but if you have a good price and it's ready we'll talk
#10 xoomer
xoomer
    1000+ Super USER!
  • 1,139 posts
  • Burien, WA
Posted 13 May 2010 - 12:57 AM
I also have the pumps and bracket, thermostat housing too, but no hoses or rack.
#11 mcbrat
mcbrat
    Brattitude Adjustment
  • Administrator
  • 11,185 posts
  • Central Iowa
Posted 13 May 2010 - 09:07 AM
Good point on the t-stat housing... the ea81 power steering quipped vehicles had a differet t-stat cover to allow for clearance of the rear of the pump....
if you go here Subarus of the 80s
to the "Some Helpful Diagrams" link in the middle column, at the very bottom of htat page, is a drawing of the diffferences....
#12 ettev
ettev
    Subaru Fanatic!
  • 369 posts
  • Pottsville, PA
Posted 13 May 2010 - 11:11 AM
I put PS on my '85 Brat and didn't swap the crossmember. Used the non-ps one. PM me and I can give you a list of "watch outs" that you'll run in to.
#13 carfreak85
carfreak85
    Temple of Fuji
  • 5,247 posts
  • Cascadia
Posted 13 May 2010 - 11:15 AM
No idea where Sugar City is, so its hard to give an estimate. If you can get the parts closer to you, I would do that, some of the stuff is pretty heavy...
#14 dec0y13
dec0y13
    USMB Regular
  • PipPipPip
  • 81 posts
Posted 13 May 2010 - 12:20 PM
If I do it, I'll need to whole set up. Like I said I may be able to get the deal from the junkyard. I just haven't gone to get prices yet.
That being said, I can never pass up a good deal :)
Sugar City in in SE Idaho here's a zip for shipping est. 83448
#15 SubaruJawn
SubaruJawn
    Legacy
  • 791 posts
  • Franklin,PA 16323
Posted 11 September 2013 - 04:55 PM
wouldnt EA82 such as GL and Loyales also work for the Brat ?
#16 TomRhere
TomRhere
    Certified BRAT nut!!!
  • 4,600 posts
  • Hillsdale, Mi. USA
Posted 11 September 2013 - 05:59 PM
It can be done... but it is not a simple "un-bolt this and bolt this on" type of swap.
I "stumbled upon" a bracket that would allow me to bolt the EA82 PS pump onto my EA81 engine. Had to modify the belt pulley, make a tensioner up, then decided to drop the whole thing. Couldn't get the belt to stop squealing.............. Do still have PS rack, just no pump.
Did find that Turboed EA81's, had a PS pump that mounted similar to the EA82's. Maybe that is the bracket I have, but I still had to modify it to fit engine and for belt clearances.
EA82 PS rack will physically bolt under the EA81 crossmember, after removing the plate mentioned earlier in this thread, and opening up the hole where the input shaft of the column attaches. Tie-rods can be a bit of a challenge to get right. Found some that would not work......
#17 SubaruJawn
SubaruJawn
    Legacy
  • 791 posts
  • Franklin,PA 16323
Posted 11 September 2013 - 06:37 PM
what if use eA82 rack lines ect... just use an EA81 pump ? or would there be issues with mating Ea81 pump to EA82 Lines ?
