EJ swap with EJ trans ?
4 replies to this topic
#1 oskar_subaru
oskar_subaru
    USMB is life!
  • 148 posts
  • Reykjavik, Iceland
Posted 16 May 2010 - 10:18 PM
i can´t find any good pictures of how you guys run a EJ trans,
do you have the driveshaft custom made ?
what do you do about shift linkages ?
what do you do about the trans crossmember ?
thanks,
Oskar K.
#2 Turbone
Turbone
    The Original Rob
  • Moderator
  • 12,203 posts
  • WA
Posted 17 May 2010 - 01:11 AM
Caboobaroo is working on this right now in his 86 RX*. He's having problems finding the right setup for the x-member as his body style is a little different, it used to have a AT in it. He had to have a driveshaft made also.
#3 suberdave
suberdave
    www.suberdave.com
  • 1,004 posts
  • Covington
Posted 17 May 2010 - 08:30 AM
thanks,
Oskar K.
i have done a few of these now.
the rear drive shaft has to be shortened. then ballanced
the shift linkage also has to be shortened.
and the crossmember you have to use a three piece member. for cars 87.5 and later you can use the front and rear sectons from an XT6 and the center piece from an impreza. for older cars, you have to cut and reweld the rear section. its about an inch to wide.
#4 T'subaru
T'subaru
    Gone but not forgotten
  • 443 posts
  • T'sunami Coast WA
Posted 20 May 2010 - 08:10 PM
I believe the drive shaft has to be shortened 2". What options are there if xt6 parts are not available? I had planned on installing my ej and ej trans and seeing if I can modify what I have to work. Is there enough under a 87.5 and up L to cut, weld etc?
#5 LeoneTurbo
LeoneTurbo
    EJ engine expert
  • 341 posts
  • Arnhem (The Netherlands)
Posted 25 May 2010 - 08:48 AM
For pics:
EA82 to EJ AWD swap
