Road trip - Finished! Weber & LSD Q's
4 replies to this topic
#1 Mendodave
Mendodave
    USMB is life!
  • 127 posts
  • Little River, California
Posted 17 February 2004 - 01:24 PM
The Subaru chomped its way to Phoenix and back, with only a few hiccups.
I got my intake manifold installed, the LSD installed, both front axles with lower ball joints, and a valve adjust.
Unfortunately, cleaning the carb cleaned out all the dirt that was blocking the vaccum leaks. the throttle shaft has massive play in it, so it is carb time....that means WEBER!
Anyone have tips on how to disconnect the smog stuff the weber doesn't use? Can I use the cruise control with the Weber?
I have heard the Redline kit is not that good, any better places to get one? (Car is a '84 GL wagon)
Also, my LSD clutch is binding, all I could find for LSD oil was Stalube, according to the board, Kendall or Redline is the best. Would the clutch bind for awhile if the LSD was dry for a month?
But the LSD works like a champ! Point at hill, go up it!
I came over the I-80 pass yesterday, 15 hours from Bishop to Mendocino, 4 hours from Boomtown to Truckee.
that was a drag.
Thanks!
Mendo Dave
#2 TheSubaruJunkie
TheSubaruJunkie
    I'M BAAAAAACK!
  • 1,922 posts
  • Sacramento
Posted 17 February 2004 - 11:58 PM
4 HOURS FROM BOOMTOWN TO TRUCKEE!!!??? Thats crazy!!
I just drove over the pass twice. Drove to Reno at around 11pm-Midnight on 2/16 and drove home around 4pm on 2/17. The pass was clear. Flood hazards cause of the rain, but other than that... no problems.
Glad to hear your car made the trip.
-Brian
#3 edrach
edrach
    RIP 6/28/14
  • 12,326 posts
  • Bothell, WA
Posted 18 February 2004 - 12:04 AM
Dave, I like http://www.carbsunlimited.com/ for my weber parts and information. They are fairly local to me and don't snicker when I tell them I want a weber for my Brat.
#4 the sucker king
the sucker king
    great fisherman
  • 1,988 posts
  • Lyons, Colorado
Posted 18 February 2004 - 09:29 PM
dave,
get in touch with me if the lsd is bad. i meant what i said, i won't leave you hangin. i can't help you solve it , tho. i don't know enough about them. did you put 3.9 gears in it?
#5 Mendodave
Mendodave
    USMB is life!
  • 127 posts
Posted 18 February 2004 - 10:10 PM
Hi Sucker King,
don't think it is bad, it seems to work fine, just you can hear/feel clutch sounds in tight 4wd corners, when there is a lot of traction.
I think I need better LSD oil. Yes, the 3.9 gears are in there, sure not going to run it without that!
thanks,
David
