92 legacy thermostat questions
5 replies to this topic
#1 ron2368
ron2368
    USMB Regular
  • PipPipPip
  • 122 posts
  • Lancaster PA
Posted 10 June 2010 - 06:03 PM
My daughter tells me the temp gauge has not shot up, but I checked the top hose was really hot and the bottom was air temp. Never was replaced.
I had got a thermostat last year and it came with a rubber ring, not with the flat gasket I have always seen. If this is the correct gasket , do I need a sealer? thanks
#2 MorganM
MorganM
    Do you Subaru?
  • 8,390 posts
  • TwinCities
Posted 10 June 2010 - 07:09 PM
No sealant needed for the housing that bolts to the water pump. Hit those bolts with some PB Blaster before you get started; the heads like to twist off and that's never fun.
The rubber seal slips over the rim of the t-stat.... tounge and grove style. There is a thin groove along the inner side of the seal. The razor thin edge of the t-stat slips into that. When you pull out the old t-stat and pull off that seal you'll see how it works. Also note the orientation of the t-stat in the water pump so you put the new one in correctly.
If you have no idea when the last time the hoses were replaced then I'd replace them... now you know! =)
Top hose should be HOT. That's where the engine pumps water out and in to the radiator. The water pump sucks it in from the bottom of the radiator. Also note that the bottom hose has an extra sleeve over it on the elbow so it's nearly twice as thick as the upper hose; this can mask how hot it really feels because there's more insulation around it.
Edited by MorganM, 10 June 2010 - 07:11 PM.
#3 Timo
Timo
    New User
  • Pip
  • 1 posts
  • Eugene
Posted 10 June 2010 - 07:22 PM
Rear Wheel bearing sound question I didn't see the post button so I'm jumping in here. The sound is a clunk clunk clunk when backing up and turning the wheel to the right. Is this a wheel bearing or differential going out. There is no sound going straight and forward.
#4 lone500
lone500
    USMB Regular
  • PipPipPip
  • 92 posts
  • Saluda NC
Posted 10 June 2010 - 07:28 PM
that would probably be your differential.
when my wheel bearing started going out i had to ask a friend of mine WTF is that sound. he said it was the bearing. sound got worse. and worse. then i fixed it.
#5 Rooster2
Rooster2
    Subaru Master
  • 4,600 posts
  • Indianapolis
Posted 10 June 2010 - 07:46 PM
Suggest you post above as a new thread. You will get more response to your question.
#6 ron2368
ron2368
    USMB Regular
  • PipPipPip
  • 122 posts
  • Lancaster PA
Posted 10 June 2010 - 08:44 PM
I had scraping noise and it was the rear caliper.
Thanks about the T stat. I put a new radiator in last summer but was too lazy to relpace the stat, thats why I already have it:rolleyes:
