EA 81 Transmission Q's
5 replies to this topic
#1 NV Zeno
NV Zeno
    Elite Master of the Subaru
  • 3,108 posts
  • Ponderosa Ranch, Nevada
Posted 18 February 2004 - 10:14 PM
Just making sure here (after a failed extensive search), The 4th gear ratio is taller on the 83/84 models than the 80-82's, right?
#2 GLCraig
GLCraig
    Frak
  • 2,706 posts
  • Canby @#$% Oregon
Posted 18 February 2004 - 10:37 PM
for ea81 d/r and s/r 4wd 83-84 has a higher ratio for both 3rd and 4th then 81-82.
#3 GeneralDisorder
GeneralDisorder
  • 22,068 posts
  • Portland
Posted 19 February 2004 - 01:11 AM
Yep - 81/82 is what you want for off-road and big tires....
83 and UP (to 89 here in the states) are all taller in 3rd and 4th
#4 Mendodave
Mendodave
    USMB is life!
  • 127 posts
  • Little River, California
Posted 19 February 2004 - 12:32 PM
Hi NV,
the graphic i saw had a breakdown of all the subaru transmissions, the 80-82 ones had the same first and second ratios, third was 25% lower, and 4th was 15% lower than the 82-84 transmissions.
I thought the taller gears would be good to have on the Phoenix trip, but I was wrong. So, my spare trans will be going in, unless I can find a DR 5speed soon.
sure would not have helped on the drive over the Sierras, I only got to second once between Boomtown and Truckee...crawling along in first
will try to find that file for you...
David
#5 GeneralDisorder
GeneralDisorder
  • 22,068 posts
  • Portland
Posted 19 February 2004 - 12:34 PM
The shorter gears make it more fun to drive - better acceleration in a stock roo.
#6 NV Zeno
NV Zeno
  • 3,108 posts
Posted 19 February 2004 - 12:46 PM
OK, thanks fellas.
Just the info I've been looking for.
Mendo:
Glad to hear you're home in one piece.
