Timing Belt: Tools Required?
25 replies to this topic
#1 WRX1AB
WRX1AB
    USMB Regular
  • PipPipPip
  • 78 posts
  • global
Posted 19 February 2004 - 05:12 AM
I have no tools and want to spend as little as possible. I am an experienced mechanic.
Can you tell me the sizes of the crank pully bolt?
I am assuming 10, 12, 14 17 and 19 for everything else.
Am I going to need a balancer puller to get off the pully?
Is it standard opperating proceedure to do teh water pump at teh same time as the timing belt?
#2 99obw
99obw
    this space for rent
  • 1,595 posts
  • Ithaca area
Posted 19 February 2004 - 07:11 AM
What year, what engine, how many miles, auto or manual?
#3 frag
frag
    Soob shade tree mechanic
  • 1,777 posts
  • Montréal, Québec, Can.
Posted 19 February 2004 - 09:52 AM
Hi,
1)All chances are your crankshaft pulley bolt head size is the same as on most Legacies (and as on mine): 22 mm
2) You dont need a puller, the crank pulley will practically fall in your hands when the bolt is removed.
3) People use different methods to immobilize the pulley while they remove the pulley bolt. I think mine is cheap and very efficient. I bought a chain wise grip for around 20$ Can and used it to remove the crank pulley as well as the cam pulleys. The beauty of this tool aside is low cost is that the relatively short handle is easily made to catch on nearby immovable parts and thus permits you to work alone with both hands free.
The only caveat is you have to use something to protect the pulleys and you should use just enough clamping force to hold the pulleys steady. I used my good old judgment and everything went fine. I used part of an old drive belt to protect the crankd pulley and part of the old timing belt to protect the cam pulleys.
4) I think you're about right for the rest of the sockets sizes.
5) Most people here, and me included, think that replacing the water pump is cheap insuraqnce. You should also replace the crank and cam seals and reseal the oil pump (an O ring + sealing compound around where the pump mates with the engine block)
Hope that helps and good luck!
#4 frag
frag
  • 1,777 posts
Posted 19 February 2004 - 09:56 AM
Just saw your alias "WRX". Maybe some of what i wrote does not apply. Others will set things straight if need be.
#5 AussieIan
AussieIan
    USMB Regular
  • PipPipPip
  • 64 posts
  • Sunshine Coast/Australia
Posted 19 February 2004 - 03:28 PM
The Haynes manual says anaerobic sealant for the oil pump, are there any specific recommendations eg Loctite ###:confused:
#6 theotherskip
theotherskip
    Eat, Live, Breath Subaru
  • 329 posts
  • Philly, PA
Posted 19 February 2004 - 05:13 PM
subaru recommends loctite ultra-gray for resealing the oil pump.
an alternative method to immobilize the crank is to put the car in 5th (if it is manual), have someone step hard on the brakes, and break it free.
#7 Legacy777
Legacy777
    Moderator
  • Moderator
  • 12,809 posts
  • Houston, Tx
Posted 19 February 2004 - 05:33 PM
ok....I do have a question about the sealant of the oil pump. I've been trying to get my hands on the three bond or whatever subaru uses. I don't think the ultra grey stuff is anerobic. I have some stuff that is.....but I'm not sure if it's exactly what I want. The damn sealant is holding me up from doing the t-belt.
#8 99obw
99obw
    this space for rent
  • 1,595 posts
  • Ithaca area
Posted 19 February 2004 - 06:24 PM
I have used permatex anerobic gasket maker with excellent results. I have also used the permatex ultra-black with equally good results. I have been too cheap to pay $10 a tube for the ultra-grey, since ultra-black has always performed flawlessly for me. YMMV
AFAIK ultra-grey is not anerobic.
Three bond 1280B is available under Subaru# S0A5499100. AKAIK this is used for the H6 camcase.
Three bond 1215 is available under Subaru# SOA635019. I think this is used everywhere else three bond is called for.
#9 WRX1AB
WRX1AB
    USMB Regular
  • PipPipPip
  • 78 posts
  • global
Posted 19 February 2004 - 06:34 PM
woops
its a 92 2.2 legacy 5speed 4x4 (not that it matters too much). hte bolt does look to be about the same as my ea81t (that was the wrx want to be. I used to be on the older gen site. I built a fulltime5 speed pushrod turbo dl wagon taht would destroy everything off the line in low range for the first 5o feet)
I measured the bolt before I left and you are right.
my favorite trick was to put the breaker bar between the ground and the skid plate and put the socket on the nut and .......................... turn the key. hte starter has way more torque than my little arms. check rotation directionfirst!!!!
anyway, thanks or the advice. I ahve no ac, so it looks to be a peice of cake. I also have no money and because it looks easy, I will skip the water pump and seals for now (well, maybe i will do the crank seal) and do them wehn I ahve more cash. I also need to do front drive shafts and my y pipe is leaking, so a little at a time.
#10 99obw
99obw
    this space for rent
  • 1,595 posts
  • Ithaca area
Posted 19 February 2004 - 06:51 PM
When you do the cam seals, the cam sprockets on the 2.2 are a PITA without the correct tool. It can be done with a chain wrench and a piece of old timing belt, but be very careful not to break the rear timing covers. You can probably build a tool.
Make sure you properly torque the crank pulley bolt with some blue (medium) loctite when you put it back together.
#11 theotherskip
theotherskip
  • 329 posts
  • Philly, PA
Posted 19 February 2004 - 08:33 PM
first posted it to the wrong thread.
from tsb #somethingsomething-something. if anyone needs it, i can look it up...
Posted Image
#12 AussieIan
AussieIan
    USMB Regular
  • PipPipPip
  • 64 posts
Posted 20 February 2004 - 02:12 AM
Permatex anarobic sealant seems to be correct. Web site is
http://www.permatex....m&item_no=51813
What do you think Josh?
#13 AussieIan
AussieIan
    USMB Regular
  • PipPipPip
  • 64 posts
Posted 20 February 2004 - 02:40 AM
Forgot to attach the product bulletin etc sorry. Ian
#14 AussieIan
AussieIan
    USMB Regular
  • PipPipPip
  • 64 posts
Posted 20 February 2004 - 02:43 AM
Sorry the're two big to attach, you can find thewm on the Permatex website anyway
#15 Legacy777
Legacy777
    Moderator
  • Moderator
  • 12,809 posts
  • Houston, Tx
Posted 20 February 2004 - 08:39 AM
I finally got a hold of someone at a few dealerships yesterday and they confirmed what theotherskip posted.... three bond part # 004403007
BTW....excellent info in that scan....I think I'll be swiping it :)
#16 99obw
99obw
    this space for rent
  • 1,595 posts
  • Ithaca area
Posted 25 February 2004 - 08:51 PM
Josh,
Did you buy any of that three bond yet? I am curious about the size of the container.
From www.subaruparts.com
004403007 Super Three Bond 1215 $20.03
SOA635019 Super Three Bond 1215 $5.00
I am guessing the only difference is the size of the container, presuming that the two are actually the same otherwise.
#17 theotherskip
theotherskip
  • 329 posts
  • Philly, PA
Posted 25 February 2004 - 09:11 PM
i have to say i've been real pleased with the permatex ultragray. easy to find and after 15k miles, i don't see any leaks anywhere - oil pump, oil pan, etc. i think you can use them interchangeably.
#18 Legacy777
Legacy777
    Moderator
  • Moderator
  • 12,809 posts
  • Houston, Tx
Posted 26 February 2004 - 09:29 AM
I decided to go with the ultra grey. It's easy to find and it's like 5 bucks
It says on that sheet it's comparable, so that's good enough for me.
#19 99obw
99obw
    this space for rent
  • 1,595 posts
  • Ithaca area
Posted 26 February 2004 - 12:49 PM
Wow, $5. Where at? It's $10 at my local Napa for ultra-grey, $5 for ultra-black.
FWIW I have never had a leak with ultra-black or the anerobic, but the blue RTV seems to be hit or miss. I won't use the blue stuff on my own cars.
A little OT, paid $23 for a bottle of blue loctite at Napa a couple of days ago. Ouch!
#20 theotherskip
theotherskip
  • 329 posts
  • Philly, PA
Posted 26 February 2004 - 05:17 PM
i got it at pep boys and autozone. around $5. i've been very down on napa. they just rebrand stuff with a napa logo and charge a lot more. i think they are more around for independent mechanics who need delivery of parts and just pass the cost on to the customer...
#21 99obw
99obw
    this space for rent
  • 1,595 posts
  • Ithaca area
Posted 26 February 2004 - 05:36 PM
I will get it at autozone next time, though I generally try and avoid them as I have had terrible luck with their junk parts. Napa parts are slightly better. I live in the middle of nowhere, and napa is two minutes away. Autozone, advance auto, and a private auto parts store are about 30 minutes away. Many times napa is too convenient and I probably pay a premium.
#22 99obw
99obw
    this space for rent
  • 1,595 posts
  • Ithaca area
Posted 27 February 2004 - 09:07 PM
While browsing my favorite tool catalog that came in the mail today I found this.
It looks like it might work great for holding those pesky 2.2l cam sprockets when replacing the cam seals. Pretty cheap too.
Posted Image
Universal Cam Adjuster
It would make a good addition to my toolbox.
#23 avk
avk
    Certified Subaru Nut
  • 965 posts
  • Somerset County, NJ
Posted 28 February 2004 - 01:18 PM
Do you think this tool can also be used, in the same way as the factory one, to hold the crank pulley? I see they do sell a tool specifically for holding the pulley, with a set of pegs in several sizes, but it costs more.
#24 DerFahrer
DerFahrer
    Formerly subyluvr2212
  • 2,420 posts
  • Orlando, FL
Posted 29 February 2004 - 12:57 PM
I didn't do my cam seals when I did my 2.2 timing belt (I should have, one is leaking now :mad: ), but couldn't you just leave whatever construct you used to keep the engine still to remove the crank pulley, in place and with the timing belt still on and tense, remove the nuts for the cam sprockets? Then to reinstall them, put the belt back on and put some tension on it, and retighten the nuts?
#25 99obw
99obw
    this space for rent
  • 1,595 posts
  • Ithaca area
Posted 29 February 2004 - 01:25 PM
I honestly do not know. I have been using a chain wrench with old belts to protect the pulley.
