Guest jimbo747 Posted August 2, 2003 Share Posted August 2, 2003 I've got an '87 GL Wagon, 1.8L SPFI. My mech. tells me I need a new idle air control. He wants over $400.00 for the part, plus installation. I found the part from a Subaru dealer in NJ for $270, but my mech. won't install it. What's involved in installing this part? Is it a simple bolt-off / bolt on replacement, or is there special tools and/or adjustments required. Thanks in advance for you help! Quote Link to comment Share on other sites More sharing options...
Guest Subi81 Posted August 13, 2003 Share Posted August 13, 2003 is that the valve that is mounted ontop of the temostat? If so you could peobably find one in a junk yard for really check. I have never heard of one going out. Good luck Quote Link to comment Share on other sites More sharing options...
Guest calebz Posted August 13, 2003 Share Posted August 13, 2003 They do go out. someone else on the board is dealing with the same problem. usual symptoms are crappy idle when cold. motor bogs down when AC is on. stuff like that.. it isn't hard to install/replace. its right in front of the TB. check the error codes on your computer. heres how <a href="http://www.westol.com/neper/ecucodes.html" target="top">Soob trouble codes</a> Oh yeah, and get a new mechanic. stop getting screwed. Quote Link to comment Share on other sites More sharing options...
