NV Zeno Posted February 20, 2004 Share Posted February 20, 2004 OK, now that I'm sure about the years/ ratios, how do I identify one from the other? Are there numbers somewhere on the body of the unit identifying the model year? Assume the transmission has been removed, and there are several to choose from. Quote Link to comment Share on other sites More sharing options...
mcbrat Posted February 20, 2004 Share Posted February 20, 2004 the '82 tranny has a smaller input shaft, and smaller throw out bearing & holder. SubaruBrat might be able to help you. I believe he has/had several backup trannies. he also had a piece milled to fit the larger TO bearing onto the smaller '82 bearing holder (I think it's how he did it), to account for the larger pressure plate 83+ Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted February 20, 2004 Share Posted February 20, 2004 Hhhmmm - yeah - the input shaft thing..... ya know, I never noticed that. Are you talking about just the tip where it slides into the flywheel? Cause I swapped that 84 2WD tranny into the 84 DL wagon, which had an 82 D/R in it prior, and then put that 82 D/R in my 84 wagon with both a 2WD, and then now a 4WD clutch.... and everything has just fit together. Have I been way lucky or something? I did notice a bearing on a JY flywheel that had a larger opening that was too big for an 82 D/R shaft..... man I am totally confused now. GD Quote Link to comment Share on other sites More sharing options...
mcbrat Posted February 20, 2004 Share Posted February 20, 2004 the splines are the same, but the shaft that the bearing holder slides on is bigger diameter on the 83+ the 82 4wd and the -84 2wd TO bearings are smaller, and when put up against the 225mm (9") PP just barely engage the fingers. Quote Link to comment Share on other sites More sharing options...
NV Zeno Posted February 20, 2004 Author Share Posted February 20, 2004 AFIK, I've got a 80-82 D/R in my '83 wagon. The clutch is stock '83. Does that mean I'm in a "just barely fit" situation? Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted February 20, 2004 Share Posted February 20, 2004 Means that likely your throw out bearing is the wrong size (too big). GD Quote Link to comment Share on other sites More sharing options...
NV Zeno Posted February 20, 2004 Author Share Posted February 20, 2004 Hmm..It's worked great configured that way since installation a couple of years ago. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted February 20, 2004 Share Posted February 20, 2004 Your clutch pedal may feel different than stock, but as long as the bearing doesn't fail, and the PP doesn't either - then I can't see anything wrong with it. Also - if you replaced the clutch AND the TO bearing AND it's carrier, then your probably fine. The little bearing in the flywheel would be the wrong size for the tranny shaft..... GD Quote Link to comment Share on other sites More sharing options...
NV Zeno Posted February 21, 2004 Author Share Posted February 21, 2004 I've always replaced the throw out bearing with the clutch, and both are relatively recent. I'm going to assume the "bearing in the flywheel" is also called the "pilot bearing", the one pressed into the flywheel? Quote Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted February 21, 2004 Share Posted February 21, 2004 Yup, thats your pilot bearing. Im going to need a new tranny soon. 3rd gear is going out on mine, and i would like to have the tranny with the lower 4th gear. Any identifiable marks would be great, anything or anyway to verify the tranny im getting is of the lower ratio. -Brian Quote Link to comment Share on other sites More sharing options...
bratsco1 Posted February 22, 2004 Share Posted February 22, 2004 Get ahold of Jerry and install a five speed. I rode in his low and mean hatch this morning and the 5 speed is the only way to go. he left Moxee Motors a while ago and had his XT seats installed...quite a ride.................Pat Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted February 22, 2004 Share Posted February 22, 2004 The 5 speed is no better than an early 4 speed with the lower 3rd and 4th. You won't really use 5th on a 5 speed, just as you won't use 4th on a later model 4 speed. But on the 81/82 4 speed, you actually CAN use 4th.... as for identifing marks - I'm not aware of any. Unfortunately, there may not be any. Pulling a trans from an 81 or 82 car that looks original would be your best bet.... you can tell if the trans came from an 81 Brat GL if the 4WD shifter is turned 90 degrees... but your chances of finding an 81 Brat GL with a good tranny is slim to none..... GD Quote Link to comment Share on other sites More sharing options...
TomRhere Posted February 22, 2004 Share Posted February 22, 2004 I may have the answer to that later this week. I have the DR4spd from my '86 sitting on the floor of the garage. I will be pulling the EA-82/DR4spd out of the '82 this week. So I will be able to do a side-by-side comparo of the two. As far as I know, the tranny in the '82 is the original one, same with the '86. Will post back with answer as soon as I have the tranny out. Quote Link to comment Share on other sites More sharing options...
