ran out of gas but shouldn't?
4 replies to this topic
#1 idosubaru
idosubaru
    Elite Master of the Subaru
  • 23,736 posts
  • East Coast
Posted 06 August 2010 - 01:23 PM
a few months ago our 2002 OBW H6 ran out of gas about 5 minutes or less after the low fuel light came on. filled it up and it took a bit over 14 gallons (what it normally takes when the fuel light comes on). but it's a 16.9 gallon tank - so why did it "run out of gas" with 2...almost 3 gallons still in there?
it seems to "run out" quicker than older gen cars, is the fuel pump set up different, sits higher or something?
i mean - yeah i know, don't run it that low, but i'm curious what the difference is and i'm definitely not keen on it running out a couple miles after the low light, that doesn't sound right.
#2 bheinen74
bheinen74
    Banned
  • Banned
  • Pip
  • 0 posts
  • central Iowa
Posted 06 August 2010 - 01:45 PM
fuel pump sock might be clogged down in the lower portion, so it can not bring fuel in when it gets low.
thats what i would check first.
#3 johnceggleston
johnceggleston
    Lite Master of the Subaru
  • 6,712 posts
  • Virginia
Posted 06 August 2010 - 04:44 PM
i can't imagine the 'small' side, driver side of the tank only holds 2 gal. but not drawing fuel from both side does come to mind.
maybe there is a hole in the "suck up" tube on one side that defeats the actual pick up.
#4 idosubaru
idosubaru
  • 23,736 posts
  • East Coast
Posted 06 August 2010 - 06:47 PM
how hard is the fuel pump stuff to get to on EJ's, i've never had to mess with those before.
#5 hankosolder2
hankosolder2
    Subaru Nut
  • 709 posts
  • Chicago
Posted 06 August 2010 - 10:25 PM
How sure are you about the actual capacity of the tank? I remember Car &Driver complaining about running out of gas in a 1st gen Impreza with a 16 gallon tank, filling the tank after it ran out and it only taking 14 gals.
Nathan
