Downshifting into 3RD...
15 replies to this topic
#1 TheSubaruJunkie
TheSubaruJunkie
    I'M BAAAAAACK!
  • 1,938 posts
  • Sacramento
Posted 21 February 2004 - 09:04 PM
Yeah, its not working anymore...
I can shift from 2nd to 3rd relativly easy, but if im downshifting from 4th to 3rd, sometimes it wont grab and the tranny will slip out of gear, which usually ends up grinding until i can grab the shifter and slam it back into 3rd again. Is this pre-mature tranny meltdown? The car is a slug in 4th gear, been thinking of doing something about it. Not sure if I wanna do the whole 5spd deal, but I would like to get 3rd gear back.
-Brian
#2 TheSubaruJunkie
TheSubaruJunkie
    I'M BAAAAAACK!
  • 1,938 posts
  • Sacramento
Posted 21 February 2004 - 09:05 PM
Oh yeah, and for those that dont know... its on the '84 Lifted Wagon, EA81 4spd Dual Range 4WD.
-Brian
#3 mcbrat
mcbrat
    Brattitude Adjustment
  • Administrator
  • 11,185 posts
  • Central Iowa
Posted 21 February 2004 - 09:09 PM
Brian,
how much clearance do you have between the shifter and the radio? in my Dad's wagon, if you shift lightly into 3rd, it'll instantly pop back out, but if you shift sold and hold it in third until your foot is totally off the pedal, it stays.... he's put 40k on it that way so far.....
#4 junkyardgabe
junkyardgabe
    WRX Goal Accomplished!
  • 558 posts
  • Lisbon Falls
Posted 21 February 2004 - 09:12 PM
what i had to do when that started to happen with mine is shift from 4th down to 2nd then back up to 3rd that and around that i couldn't shift into 1st with out coming to a complete stop which sucked
#5 TheSubaruJunkie
TheSubaruJunkie
    I'M BAAAAAACK!
  • 1,938 posts
  • Sacramento
Posted 21 February 2004 - 09:36 PM
Thats the problem Mick, i dont have any room at all between 3rd and my radio. Since the radio isnt stock, it sticks out more. I could shift hard into 3rd anytime I'd like, and ensure its stays in gear, but i'd have to buy a box of bandaids for my knuckles.
-Brian
#6 calebz
calebz
    Andys Coupe killed my cat
  • Administrator
  • 7,547 posts
  • Tacoma
Posted 21 February 2004 - 09:47 PM
I see 2 possibilties. First, its not making it all the way into gear beacause of the radio. Fix : bend the shifter a little to provide more clearance. Second.. synchros in 3rd are going kaput.. Fix: D/R 5 speed.
#7 Skip
Skip
    Flatuous Blather
  • Moderator
  • 8,991 posts
  • Latrobe, Pennsylvania
Posted 21 February 2004 - 10:00 PM
You could fix the slop in the shifter and at the same time incorporate the short shifter fabrication I sent you three months ago for the USRM
#8 TheSubaruJunkie
TheSubaruJunkie
    I'M BAAAAAACK!
  • 1,938 posts
  • Sacramento
Posted 21 February 2004 - 10:16 PM
Yeah, something I need to do. The shifter doesnt need to be any shorter. With the 3" lift, the shifter is already 3" shorter.
-Brian
#9 Skip
Skip
    Flatuous Blather
  • Moderator
  • 8,991 posts
Posted 21 February 2004 - 10:29 PM
Sorry for not being specific.
The fabrication I sent you, does not "shorten the shifter"
It shortens the throw of the shifter.
i.e. how far the shifter moves between shifts
Which in this case, may help
BTW
My Brat had the same problem
#10 TheSubaruJunkie
TheSubaruJunkie
    I'M BAAAAAACK!
  • 1,938 posts
  • Sacramento
Posted 21 February 2004 - 10:46 PM
Yes, shorter throw would be alot better. Guess i better dig through the old email and find that :)
-Brian
#11 NV Zeno
NV Zeno
    Elite Master of the Subaru
  • 3,103 posts
  • Ponderosa Ranch, Nevada
Posted 21 February 2004 - 10:50 PM
Brian
Looks like we're headed for a "Double Tranny Swap Wrench Fest", eh?
#12 TheSubaruJunkie
TheSubaruJunkie
    I'M BAAAAAACK!
  • 1,938 posts
  • Sacramento
Posted 21 February 2004 - 11:09 PM
maybe, we'll just have to wait and see :)
Tranny givin you trouble too?
-Brian
#13 torxxx
torxxx
    I void warranties
  • 2,918 posts
  • Fairbanks
Posted 21 February 2004 - 11:15 PM
I agree with the shorter stick shift.
I was looking at it on my EA82 and I think one could cut 3 inches off the stick and then rethread the stick
#14 richierich
richierich
    Moderator
  • Moderator
  • 3,760 posts
  • Portland
Posted 22 February 2004 - 02:09 AM
the EA81 4spd Transmission is know for having a bad 3-4 gear shift fork. But yours just might be the snychros. Either way, sounds like might be time for a conversion.
Richie
#15 clantieri
clantieri
    Subaru Freak
  • 521 posts
  • Hebron, CT
Posted 22 February 2004 - 08:21 AM
Way back when my 83 wagon did that too. I started just not using 3rd, sucked on hills, though. If you need a D/R 4 speed, let me know. I may be able to bring one out west for you in a few weeks.
Chris
#16 Mendodave
Mendodave
    USMB is life!
  • 127 posts
  • Little River, California
Posted 22 February 2004 - 09:55 PM
I need to do mine, too. I want to put the earlier one I have in there, with the lower 3rd/4th
let me know if we could get together and do these.
I'd rather find a 5speed, but I do have this trans sitting here.
d
