EA82T BOV
10 replies to this topic
#1 Guest_xforxlifex_*
Guest_xforxlifex_*
  • Guests
Posted 09 August 2003 - 09:43 AM
Will a blow off valve work well with an EA82T(89 rx 3dr hatch) if your boosting around 10-12 psi? If so what brands are suggested?
#2 Guest_electryc monk_*
  • Guests
Posted 09 August 2003 - 11:24 AM
funny i have not heard anothing on a BOV for the system of the EA82T......... interesting eh?
#3 Guest_SOOBME_*
Guest_SOOBME_*
  • Guests
Posted 09 August 2003 - 11:30 AM
Get one off of an RX7 or an Eclips, they are "by pass" valves and can be plumbed back into the intake hose <span style="color:red;">before</span> the turbo and <span style="color:blue;">after</span> the AFM and they will work fine;)
#4 Guest_Skip_*
Guest_Skip_*
  • Guests
Posted 09 August 2003 - 01:15 PM
I run a Volvo, but Saabs have been used as the others mentioned
Note because of the MAF employed by an EA82T a By Pass Valve (BPV) is recommended over the Blow Off Valve (BOV) as the metered air is fed back into the system.
Hope this helps
<img src="http://www.westol.com/neper/willyengwdescsmall.jpg"/>
#5 Guest_archemitis_*
Guest_archemitis_*
  • Guests
Posted 09 August 2003 - 01:46 PM
i have never seen a starion intercooler that shape, arent they longer?... i like the ford and mada(turbo 626 and probe) bypass valves over the mitsubishi, or volvo, cuz they are bigger, where the boost flows through, and where it shoots it out. very easy to plumb inline too... but its plastic:p
#6 Guest_carfreak85_*
Guest_carfreak85_*
  • Guests
Posted 09 August 2003 - 03:13 PM
actually i was reading an article that compared a bunch of stock and aftermarket blow off valves, etc. and the OEM WRX recerculation. valve had the best overboost and oscillation control of any of the valves tested. just a thought! i can supply scans of the article if anyone is interested.
#7 Guest_carfreak85_*
Guest_carfreak85_*
  • Guests
Posted 09 August 2003 - 03:15 PM
actually the WRX valve had the best overboost and oscilation of any OEM or aftermarket valves tested in a comparison in Sport Compact Car. i can supply scans of the article to anyone who wants to check it out.
#8 Guest_xforxlifex_*
Guest_xforxlifex_*
  • Guests
Posted 09 August 2003 - 07:39 PM
ok so still a little confused but what would happen if i did go and put an aftermarket BOV on an ea82t, if that would even work.
#9 Guest_Marck_*
Guest_Marck_*
  • Guests
Posted 09 August 2003 - 09:18 PM
Can I get a scan of that article...my email is mhasbun@calpoly.edu
#10 Guest_calebz_*
Guest_calebz_*
  • Guests
Posted 09 August 2003 - 09:23 PM
Someone(oddcomp?) just did a little write up a couple of weeks ago about using a saab(bosch) BOV on an ea82t. seems to have met with success.
#11 Guest_Subi81_*
Guest_Subi81_*
  • Guests
Posted 13 August 2003 - 11:43 AM
Will be putting in a volvo bpv in an intercooled 86 turbo wagon within a week or two. Will post thoughts, pics, ect.
