Scott in Bellingham Posted August 14, 2010 Share Posted August 14, 2010 sold a car so Im ready to build up another The culpret: I picked up a 86 GL 3DR white Coupe, its a Automatic with a Carbed EA82 1.8 the plan junk the engine and tranny add EJ 2.5 with dual cam heads , all stock wiring and ECU from a 98 Leg Weg add 3.9 Dual Range going with a big lift on this one maybe 6" maybe taller 7 or 8 30-31" tall Mud Terrains Nissan 720 truck front Diff, axles and hubs will replace the rear diff and axles and Hubs , this will give me a stronger rearend and axles and the diff will bolt right in using the stock diff hanger and stock Soobie driveline , also with the rear diff weled I will be able to unlock the rear hubs using the Nissan 720 hubs which also are 6 bolt so I will drill the front hubs to match, this car will become my daily driver and have the EJ 2.5 power to pull a trailer and have some bigger rear discs to stop it, will start the build first with building and installing the lift and pullin the engine and trans, will have Adam at Norhtwest Rally Sports in Bellingham WA wire up the monster engine , Huummmm should I get some Delta cams while Im at it? HhHHhhhhmmmmmmm may be a while before this all starts but Im just excited and wanted to share , been talkin to Adam for a while about the engine, Ive never had a 2.5 befor Quote Link to comment Share on other sites More sharing options...
eulogious Posted August 14, 2010 Share Posted August 14, 2010 Sounds like fun Scott! Is this the car that we picked up? If it is, glad to see it getting put to use I need to get up there and help you out. You will have a PM coming here shortly... This should be a good build. Haven't seen any subies built up for towing AND dd use.... Quote Link to comment Share on other sites More sharing options...
michael appel Posted August 15, 2010 Share Posted August 15, 2010 You havent seen mine then plus I have 1/4 in quarterpanels of diamond plate steel Sounds like fun Scott! Is this the car that we picked up? If it is, glad to see it getting put to use I need to get up there and help you out. You will have a PM coming here shortly... This should be a good build. Haven't seen any subies built up for towing AND dd use.... Quote Link to comment Share on other sites More sharing options...
SoobieDoo Posted August 19, 2010 Share Posted August 19, 2010 :cool:, Scott... After pulling rear axles for street driving a dozen times now, the idea of (un)locking hubs sounds sweet. Can't wait to see how you mate up the hubs-carrier!!! Quote Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted August 26, 2010 Author Share Posted August 26, 2010 Update going with a 6" lift, got most of it built tonight the 2.5 fell threw so Im going with a EJ22 got a set of Torque grind Delta Cams for it, looks like Saturday we will start into the car, thinkins a Red White and Blue paint job is in order Quote Link to comment Share on other sites More sharing options...
brysawn Posted August 26, 2010 Share Posted August 26, 2010 Update thinkins a Red White and Blue paint job is in order Always classy Quote Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted August 26, 2010 Author Share Posted August 26, 2010 Always classy the car is white at the moment, been lookin on line for some ideas Quote Link to comment Share on other sites More sharing options...
TeamCF Posted August 26, 2010 Share Posted August 26, 2010 Nissan 720 truck front Diff, axles and hubs will replace the rear diff and axles and Hubs , this will give me a stronger rearend and axles and the diff will bolt right in using the stock diff hanger and stock Soobie driveline , also with the rear diff welded I will be able to unlock the rear hubs using the Nissan 720 hubs This will be neat to see done. Could be just the ticket. Quote Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted August 26, 2010 Author Share Posted August 26, 2010 This will be neat to see done. Could be just the ticket. it will physically bolt right in , looks like 4.3 to 1 ratio , so rear tires will be bigger then front Quote Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted August 27, 2010 Author Share Posted August 27, 2010 here it is jig weldin up the rear Hammerite Grey paint Quote Link to comment Share on other sites More sharing options...
eulogious Posted August 27, 2010 Share Posted August 27, 2010 Nice progress! I just cleared it with my boss, so I will be getting off work early, so I should be able to be up to your place between 9-10am I look forward to seeing what you got planned and how you are going to do it! Quote Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted August 29, 2010 Author Share Posted August 29, 2010 todays progress with some great help from a couple o board members old EA82 Carbed engine and burnt Auto trans out, 3.9 Dual Range installed EJ 2.2 installed with Delta Torque Cams ( cams installed today, and found woodruff key keyway and pulley and timing gear shot, keyways damaged, got it welded up and ground and good parts installed alll today) 6" lift blocks mounted on engine crossmember, and radius/tranny crosssmember Quote Link to comment Share on other sites More sharing options...
SoobieDoo Posted August 29, 2010 Share Posted August 29, 2010 Yeah, I'd say that's fair progress for one day. Have you run it yet, or need any help with the wiring? Quote Link to comment Share on other sites More sharing options...
eulogious Posted August 30, 2010 Share Posted August 30, 2010 That wiring is very special, I tell you what :-\ Took me two hours of sorting through it to get it into that shape, and it still needs help The harness needs a good going through with an soldering iron and heat shrink, but it "should" run That is if it's done correctly. All I did was sort it out, and that's a big start. So I don't if the person who did it originally did it correctly, and I could only verify it so much, so if it doesn't run it will be interesting diagnosing it :-\ But not impossible. He's hoping the reason it wasn't running before was because of the woodruff key being all messed up and then causing the key way to get all messed up as well. So now that that's all fixed it should run... It was fun working on the car though, I learned alot! Quote Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted August 30, 2010 Author Share Posted August 30, 2010 That wiring is very special, I tell you what :-\ Took me two hours of sorting through it to get it into that shape, and it still needs help The harness needs a good going through with an soldering iron and heat shrink, but it "should" run That is if it's done correctly. All I did was sort it out, and that's a big start. So I don't if the person who did it originally did it correctly, and I could only verify it so much, so if it doesn't run it will be interesting diagnosing it :-\ But not impossible. He's hoping the reason it wasn't running before was because of the woodruff key being all messed up and then causing the key way to get all messed up as well. So now that that's all fixed it should run... It was fun working on the car though, I learned alot! could you figure out the wiring diagram and bring it next time, so we could just identify wires and hook it up , thanks Quote Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted August 30, 2010 Author Share Posted August 30, 2010 Heres the nissan 720 pickup front setup the diff bolts right in , will need to get one more long axle , this will go in the rear Quote Link to comment Share on other sites More sharing options...
eulogious Posted August 30, 2010 Share Posted August 30, 2010 could you figure out the wiring diagram and bring it next time, so we could just identify wires and hook it up , thanks Yup yup, I was planning on it I will also bring my iron as well and some inline fuses to wire it up properly, since this will be your daily driver I think that I got some wire loom around here as well that I could bring up. But either way I will send you the info so that you got it on hand to be able to get it wired in, whether I do it or someone else. I don't mind doing it, it's good practice Quote Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted October 13, 2010 Author Share Posted October 13, 2010 ITS ALIVE well almost had it runnin for the first time tonight, thanks to Eric on the wiring and everyone else that had a hand in it, its alive just turn the key and varoom, still need to hook up a bunch o stuff, cool its always exciting when you bring a machine back from the dead and this one has a new heart , cant wait to try out that Delta cammed EJ , woot woot Quote Link to comment Share on other sites More sharing options...
r_kirky Posted October 13, 2010 Share Posted October 13, 2010 Hammerite Grey paint Where is the signature purple? Cool build! Quote Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted October 13, 2010 Author Share Posted October 13, 2010 Where is the signature purple? Cool build! I need some direction on the exhaust, I would like to make my own header, if so what should the pipe diameters be and what should the lengths be, also I would like to use the stock y pipe head flanges up untill they turn into pipe, so keep the y at the head, or should I do 4 individual pipes?? , my 2.2 is a dual port, thanks, Quote Link to comment Share on other sites More sharing options...
Subarutex Posted October 13, 2010 Share Posted October 13, 2010 Scott... I had one of these on my wagon for a time: http://cgi.ebay.com/ebaymotors/OBX-Exhaust-Headers-98-05-Subaru-Impreza-2-5RS-2-5L-RS-_W0QQcmdZViewItemQQfitsZMakeQ3aSubaruQQhashZitem2eb088d99aQQitemZ200530254234QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories Equal length, sounded like a honda. More power in the upper rpms though. I know have one of these: http://cgi.ebay.com/ebaymotors/SUBARU-LEGACY-GT-1997-2005-2-5RS-STAINLESS-HEADER-4DOOR-_W0QQcmdZViewItemQQfitsZMakeQ3aSubaruQQhashZitem255d3f85aeQQitemZ160478234030QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories#ht_4474wt_1164 Unequal length, sounds like a Subaru on roids (coupled with a 2.25" exhaust and flowpro muffler). Good torque, good power. Its perfect! Thats the design i would shoot for. I'm guessing dia. is around 1.5" coming off teh heads. Quote Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted November 22, 2010 Author Share Posted November 22, 2010 Drove it up and down the road for the first time yesterday, boy this things a Hot Rod , sold my other coupe so this one will become my daily D finally got a GL again missed the Map lights and the tach , its drivable , still need to wire in the fuel pump wire , not sure what to do on that one, also not sure what temp is readin its wired in but seams low Quote Link to comment Share on other sites More sharing options...
ninjaben43 Posted November 22, 2010 Share Posted November 22, 2010 the ej temp sending unit reads half what ea's do(when its reading a quarter temp it is really half, or if its at half- its hot) on the manifold there are two sending units, mtnman38 drilled one out and tapped it to put in a ea sensor. worked great. and adam at nwrs can help with a relay for the fuel pump if you dont have the original. did you get the main relay for the ecu? if you run without it you will have to unplug the battery overnight or the ecu will drain it. awesome build scott. Quote Link to comment Share on other sites More sharing options...
987687 Posted November 22, 2010 Share Posted November 22, 2010 To fix the temp issue, why not just put a resistor of the correct value between the temp signal wire and ground. Quote Link to comment Share on other sites More sharing options...
SoobieDoo Posted November 24, 2010 Share Posted November 24, 2010 The temp is going to be low without a resistor, but it's wired up to the better of the two temp senders. At least on my rig, you should start to be concerned at 1/2, and it's HG time at 3/4...tested with an infrared thermo. Quote Link to comment Share on other sites More sharing options...
