In what direction is the thermostat placed?
23 replies to this topic
#1 mountainbikeak
mountainbikeak
    USMB Regular
  • PipPipPip
  • 76 posts
  • anch
Posted 15 August 2010 - 05:44 PM
Pretty lame I know, I searched for something here with no luck. Which way does this thing go in or does it mater? Thanks in advance.
#2 987687
987687
    Rally Suby!
  • 4,164 posts
  • Northern Maine
Posted 15 August 2010 - 06:30 PM
With the spring end down and the pointy end up
#3 mountainbikeak
mountainbikeak
    USMB Regular
  • PipPipPip
  • 76 posts
  • anch
Posted 15 August 2010 - 06:39 PM
I realized I didn't make my question too clear. Got the spring down, does it matter which way the loose toggle thing sits?
#4 AWD TURBO!
AWD TURBO!
    USMB is life!
  • 205 posts
  • vancouver
Posted 15 August 2010 - 07:18 PM
ware did you get your thermostat?
i get mine from the dealer for a good reason others don't work right they over heat your car!
#5 987687
987687
    Rally Suby!
  • 4,164 posts
  • Northern Maine
Posted 15 August 2010 - 08:45 PM
As awd turbo said, you should only ever use a genuine subaru thermostat. They're like $15.
The pin thing is called the jiggle pin, it lets air bubbles in the system get out into the rad. IIRC on mine it's facing the back of the car, but I doubt it matters. The thermostat is round so it shouldn't make a difference.
#6 mountainbikeak
mountainbikeak
    USMB Regular
  • PipPipPip
  • 76 posts
  • anch
Posted 15 August 2010 - 09:17 PM
Thanks guys... I did get the thermostat from the dealer and just wanted to make sure as I also noticed it was round. Thanks again.
#7 SuBrat84
SuBrat84
    What's REALLY going on???
  • 1,520 posts
  • Tucson
Posted 15 August 2010 - 10:34 PM
It shouldn't matter. But, try to get it where it looks like it will have the best 'flow rate.' :)
#8 GeneralDisorder
GeneralDisorder
    Elite Master of the Subaru
  • 21,136 posts
  • Portland
Posted 16 August 2010 - 01:42 AM
Spring side is always toward the engine.
#9 sl33py
sl33py
    USMB Regular
  • PipPipPip
  • 94 posts
  • Seattle
Posted 16 August 2010 - 03:59 PM
let me intrude and ask another noobish q...
I saw in the subaru EA "performance" (lol i know) post (here) about replacing w/ a lower temp Tstat - to open it sooner. I'm not really chasing HP (i know better), but like it running cooler when possible.
So to my point and Q - anyone know parts numbers for the 170 or 180* Tstat's?
The relevant info from that site:
Thermostat
The thermostat is one of the most overlooked performance enhancements. By reducing the operating temperature of the engine a number of things happen.
First, volumetric efficiency is increased. That is when the engine runs cooler the air/fuel mixture entering the engine is also cooler. A cooler mixture means the mixture is more dense. The higher the mixture density the more that can be packed into the cylinder. You would be surprised how much more responsive the engine becomes just by changing the thermostat from 195°F to 180°F.
The next step would be a 170°F thermostat. 170°F thermostats for the EA series engine are hard to find however almost any 170°F thermostat with a 54mm diameter will work. The little 'jiggler'' valve is not required but its preferable. The valve helps to purge air in the system and allows a slight flow of water around the thermostat to eliminate any temperature differentials between the area around the thermostat and the engine itself.
Second, with the combustion clambers running cooler a lower octane fuel can be used. Or if you're looking for better low-end torque, you can advance the ignition timing a few degrees without having to worry about detonation. (Author's note: After installing a 160°F thermostat the performance increase was negligible. However, I was able to advance the ignition liming another 2° and use 87 octane[R + M/2] gasoline with NO detonation at all!)
Thanks!!
rob
#10 987687
987687
    Rally Suby!
  • 4,164 posts
  • Northern Maine
Posted 16 August 2010 - 04:43 PM
You don't want the engine running to hot. But you don't want it to cool either. It's designed to run at 180 so let it :)
#11 GeneralDisorder
GeneralDisorder
  • 21,136 posts
  • Portland
Posted 16 August 2010 - 05:04 PM
Yes - changing the thermostat to a lower temp one is of dubious performance potential. You are talking fractions of a HP on an engine of this size.
The potential for damage due to the engine not reaching it's proper temperature is not worth the benefits. Especially on an engine with 100k+ on it. The components are used to running at a specific temp - if you change that then metals don't expand as much as before, tollerances change, and oil viscocities change - making the probability of damage that much higher.
That page has a lot of poor performance sugestions. It should be taken down or changed.
#12 sl33py
sl33py
    USMB Regular
  • PipPipPip
  • 94 posts
  • Seattle
Posted 16 August 2010 - 06:14 PM
Thanks GD! I appreciate the validation (or whatever the opposite is)... I typically take everything i read online w/ a grain of salt, but it made sense to me.
I only have 11k on my engine, so maybe a 180 vs 195 would help? Not with HP, but just long term cooling?
with so few miles, i'm not really in a rush one way or the other, but mine did sit quite a bit and working out some quirks as we go.
Thanks!
rob
#13 Subarule
Subarule
    Subaru Fanatic!
  • 500 posts
  • Southwest WA
Posted 16 August 2010 - 06:53 PM
Not true.
#14 AWD TURBO!
AWD TURBO!
    USMB is life!
  • 205 posts
  • vancouver
Posted 16 August 2010 - 10:33 PM
why do you say that? but you can do as you want i just post this from experience of the problems i've had with new thermostats that just did not work right
#15 Subarule
Subarule
    Subaru Fanatic!
  • 500 posts
  • Southwest WA
Posted 17 August 2010 - 10:17 PM
I bought a new t-stat online, from Rock Auto, I think about a year to 18 months ago. It is a Beck Arnley and was advertised as a direct replacement. So not from a Sube dealer.
It has been fantastic. The gauge (and there is nothing wrong with the gauge) reads mid-way between Cold and the half-way mark to Hot. So at about the 1/4 mark. It is a 180 degree stat (direct replacement for my year & model).
Today I drove 120 miles round trip and was in stop & go traffic around 4:30 pm in Portland, OR, trying to get on the bridge over the Columbia on I-5 into WA, just like thousands of other cars. The outdoor temp today was in the mid-90s and it felt like blast furnace - that super-hot, super dry desert air. And my t-stat never rose.
I'm extremely happy with it & see no problem ordering online from a parts vendor where I can get a direct match.
#16 987687
987687
    Rally Suby!
  • 4,164 posts
  • Northern Maine
Posted 18 August 2010 - 07:38 AM
Some brands are better than others, some people have better luck than others. But there are TONS of stories about aftermarket t-stats causing big issues that the majority of us will just spend the extra few $ to get a subaru one.
#17 SuBrat84
SuBrat84
  • 1,520 posts
  • Tucson
Posted 18 August 2010 - 11:43 AM
If it is bled properly.. (Filled up, started, warmed up so the t-stat opens, and filled the rest of the way while the coolant is flowing.) Any "Direct Replacement" t-stat will work. The reason we want Genuine Subaru T-stat is because it has a "jiggle valve" that allows a small amount of coolant to trickle through at all times and is a BIG help in preventing air bubbles in our cooling system.. that ends up in hot spots that ends up in blow head gaskets or worse. It doesn't 'trickle' enough coolant to affect the proper operating temperature range.
And, I'm sorry I have to comment about the "blast furnace hot dry desert heat" comment from PORTLAND. It NEVER gets "blast furnace" up there. (I spent 6 years in Columbia/Clatsop counties.) You are just used to that cold disgusting 9 months of rain so when it gets 'warm' you feel like you're cooking. Come spend a summer down in Tucson or (even worse, Phoenix) where it is 100+ daily for a few months. There is always a good week every summer that we get 110+ daily with below 10% humidity. THAT's blast furnace. (I've been in Phoenix where it was still 100+ at 11 at night!!) We pray for a nice cloudy with a breeze day where it gets down to the mid 90's.
#18 Subarule
Subarule
    Subaru Fanatic!
  • 500 posts
  • Southwest WA
Posted 18 August 2010 - 12:45 PM
My t-stat was installed at my auto repair shop.
If you know Portland & you know Phoenix & Tucson (and I know them well, along with Tucumcari, Gallop, and Banning and Indio and Blythe) then you know that when Portland gets temps in the 90s and next to no humidity then it feels like a blast furnace. I am very familiar with the high & low desert areas in the western half of the U.S. so I know what blast furnace temps feel like. I am not from here but from one of the driest, high desert cities in the U.S.
#19 NV Zeno
NV Zeno
  • Gold Subscribers
  • 3,100 posts
  • Ponderosa Ranch, Nevada
Posted 18 August 2010 - 12:55 PM
I can't believe this thread has gone this far. The OP asked a simple question, and was answered "...spring side down" in like the first couple of posts.
Enough already!
#20 987687
987687
    Rally Suby!
  • 4,164 posts
  • Northern Maine
Posted 18 August 2010 - 02:32 PM
actually. that wasn't the question. The question was witch direction does the jiggle pin go. Which I answered. But anyway...
#21 1-3-2-4
1-3-2-4
    Subaru Mike!
  • 3,778 posts
  • Greenwich
Posted 18 August 2010 - 02:40 PM
reminds me of the edmunds page I saw yesterday saying it's ok to drive a little ways to the auto parts store without an air filter in so you can make sure you have the right filter...
:rolleyes:
#22 987687
987687
    Rally Suby!
  • 4,164 posts
  • Northern Maine
Posted 18 August 2010 - 02:43 PM
:rolleyes:
If one was going to do that, I don't understand why they wouldn't just leave their filter in, then take it out to check at the auto parts store... :confused:
#23 1-3-2-4
1-3-2-4
    Subaru Mike!
  • 3,778 posts
  • Greenwich
Posted 18 August 2010 - 02:45 PM
That's what I was thinking too..
http://www.edmunds.c...86/article.html
#24 987687
987687
    Rally Suby!
  • 4,164 posts
  • Northern Maine
Posted 18 August 2010 - 02:47 PM
By the way, it's okay to drive a car short distances without an air filter (something you can't do with a missing fuel filter).
I'm surprised they didn't say you could duct tape the fuel line together and drive it without the filter...
