jasthefarmer Posted August 20, 2010 Share Posted August 20, 2010 hi, ive got a 91 brat pickup and was goin to adjust the valves,but how do i tell which variety of lifters i have, solid or hydralic? as i understand it,hydraulic lifters need no adjustment.cheers Quote Link to comment Share on other sites More sharing options...
84gl Posted August 20, 2010 Share Posted August 20, 2010 in less the engine has been swapped out It should be hydro Quote Link to comment Share on other sites More sharing options...
mcbrat Posted August 20, 2010 Share Posted August 20, 2010 do you have a small rectangular sticker on your valve covers? the hydro ones came with a sticker on to let you know not to adjust... of course, in nearly 20 years, lots could have happened... if you pull a valve cover off, look at where the rocker arms are attached. if hydraulic, there will be a locking tab washer on each, with the tab bent up so you can't adjust the nut.... Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted August 20, 2010 Share Posted August 20, 2010 You can also look at the push-rods themselves - hydro are steel single-peice units while the solid lifter one's have caps on the ends. GD Quote Link to comment Share on other sites More sharing options...
jasthefarmer Posted August 21, 2010 Author Share Posted August 21, 2010 well theres no stickers, i,ll check under the covers next,might wait till ive got some new gaskets i reakon. thanks Quote Link to comment Share on other sites More sharing options...
