EA-81 rebuild questions
1 reply to this topic
#1 IsLegend9
IsLegend9
    New User
  • PipPip
  • 10 posts
  • Albany
Posted 22 August 2010 - 08:02 PM
A few opinion questions for the EA81 buffs on here.
1. Best spark plug for stock '81 auto EA-81?
2. Any particular brand / size / shape of circlip pliers for installing circlips on piston pins?
3. Any particular brand / type of silicone sealant for the case halves (and wherever else it might be used in assembling the engine)?
#2 Crazyeights
Crazyeights
    Crazyeights
  • 1,435 posts
  • Pacific Northwest
Posted 22 August 2010 - 08:20 PM
1. Stock plugs should be fine, NGK perhaps?
2. Regular needle nose pliers are fine for this. Use a Ring expander to put the rings on the pistons so you don't scratch the pistons. You will need to make or buy a tool for pulling the piston pins as well as a large allen wrench or socket for pulling the access plugs.
3. Subaru 3 Bond, or Loctite 518 for the case halves. I'm sure there are others you could use also.
Edited by Crazyeights, 22 August 2010 - 08:24 PM.
