Shimmy over 60
4 replies to this topic
#1 2007imp
2007imp
    New User
  • PipPip
  • 11 posts
  • suptown
Posted 26 September 2010 - 08:26 PM
Just installed 4 new kybs in my 05 legacy sedan and now have a shimmy/vibration when going over 60. Could it need an alingment,It didn't have shimmy before. I made sure to mark the camber bolt and put back in orignal position.Could the new struts make the worn components be more felt ie balljoints/tierods/bushings. Thanks
#2 nipper
nipper
    Semi Elite Master of the
  • 18,179 posts
  • Long Island NY
Posted 26 September 2010 - 09:22 PM
Usually a shimmy over 60 is a wheel balance issue, and yes it can just happen. Does it go away at 70-75?
Rotate the tires to see if it moves.
#3 bstone
bstone
    Certified Subaru Nut
  • 875 posts
  • Great Midwest, USA
Posted 27 September 2010 - 01:38 AM
Can also be sway bar links.
#4 94Loyale
94Loyale
    I Love EJ22's
  • 461 posts
  • Orwigsburg,Pennsylvania
Posted 27 September 2010 - 06:38 PM
Agreed with Nipper, usually a tire balance/tire pressure issue. Loose inner tie rod ends will make themselves evident at that speed also.
#5 2007imp
2007imp
    New User
  • PipPip
  • 11 posts
  • suptown
Posted 30 December 2010 - 07:47 PM
Problem finally fixed.Front drivers side wheel bearing bit the dust.Now drives like new.
